Measures the rpm drop of the engine when each cylinder is cut off. If the rpm doesn't drop as much on a certain cylinder it could be a sign of something going on. Maybe you should double check your pushrod length and rocker arm setup. Maybe the rockers on one side of the engine are lose or setup improperly.
