For some reason, I cannot seem to save a EIO Output configuration.
There is no save/"disk" icon. Has anyone run into the same problem?
Am using v.2.263
Am using v.2.263
When you close(small x under larger x in top right corner) it will give you the option of saving.
still doesn't work.. I right-clicked to "Configure Output", which pops up the small window to configure the two outputs.. when finished configuring,
I exited this small window and nothing was accepted/saved
If I hit return on any of the Disable Trigger or Enable Trigger formulas,
I just get beeps
am i missing something obvious?
It’s a known bug in the current beta version- no fix out yet.
Any update on this, I have the current Beta and it doesn't save. I'd like to use the outputs for lean AFR under boost.
RHS Block 427, Mast/ PI 275 Heads, A&A YSi SC, 3.125Pulley, 238/254 LSA116+5, Flip Drive, AR 1 7/8 Headers, Corsa Touring Cat Back, RPM Level VII Tranny/ Flexplate/ Drive Plate, PFADT Carbon Fiber Drive Shaft, RPM rebuilt DTE Stage 4 3.42s, Vigilante 3 Disk 2600 converter, Custom Fuel System with Dual A1000 Pumps, ID 1000 injectors, Triple Nozzle Alky Control, 3 Bar SD Tune using 2.5 MAP. 935rwhp 800rwt
bump
