Immediately after a cam swap i'm now getting both codes as fast as I can get them (2nd drive cycle immediately)
i've scoured the internet, read hotrodlane - http://www.hotrodlane.cc/New%20LS%20...or%20P0332.htm and everything else I can find and I can't find the actual details of what specifically the low voltage codes mean aside from what the name implies.
I believe what the sensors are seeing is the newly introduced valvetrain noise with the new cam & valvetrain, I can't hear any knock, the knock sensors still seem to detect and deal with occasional burst knock while driving around. no mechanical faults are apparent.
Can the knock table be used to adjust for this? does increasing or decreasing the multiplier increase or decrease the sensitivity of the sensors? I understand by changing the cam the manifold pressure & load is different than it was stock.
drivetrain is an 01 fbody pullout wired into a 97 bmw 3 series. I put ~7k miles on the "new" knock sensors with no issues until the cam swap - went to 243 heads and a 226/230 EPS cam - ls7 lifters & 7.425 pushrods.
any help or insight is much appreciated.
