Results 1 to 14 of 14
Thread: Boosted Ls1 240sx (Not starting)
    Jul 2011
    15
    Hi guys, Trying to get this ls1 started, In the scanner under as far as codes go it gets crankshaft re-learn, now Ive seached and searched and found that its in bi-di controls but hw do you get to those settings, here's my setup:
    -ls1 shortblock (camaro)
    - 317 heads w/ comp 918's
    - MLS and arp head studs
    - aftermarket fuel rails
    - 120lbs injectors (lucas)
    - aem injector driver
    - 76mm turbo
    - tial mvs
    - ati dampner pulley
    - 2004 GTO 5.7l pcm
    - ls1 corvette harnes pinned to gto.
    - camaro TB
    - th350 Built by JW.
    The car cranks but no turn on, Im by myself so I cant check for spark, fuels there but dont know if injectors are firing.
    Heres my tune I have hp tuners pro w/ mpvi controller and 3bar map sensor.
    Any help would be greatly appriciated. Also I have found my flow rate calculator, so I still havent put that in yet.
    Senior Tuner Google's Avatar
    Sep 2010
    Saint Peters, Missouri
    1,303
    Quote Originally Posted by LS1 240sx View Post
    - 76mm turbo
    - tial mvs
    - 2004 GTO 5.7l pcm
    - camaro TB
    1st change your Dynamic Airflow High RPM Disable to 12800
    2nd P1626 set to 3 no error reported
    It should start with #2 corrected..
    We Can Fix Your Bricked PCM Or Your YYYYYY OS ID
    Jul 2011
    15
    Changed, but no start.
    Jul 2011
    15
    and for some reason scanner wont connect.
    Sep 2010
    1,303
    You need to check your powers and grounds.. wiring to the cam and crank sensors, coils, and injectors..
    Sounds like a wiring issue..
    5BA8
    3,254
    Crank relearn will never ever cause a no start condition.
    Go back to the basics. Do you have fuel pressure? Do you have crank sensor pulse (RPM signal on your scanner while cranking)? Do you have injector pulse and spark? Does it pop and spit or does it do nothing?
    Too many people come on and ask for tuning help for no start conditions and overlook the basics needed for operation. Theory always is it's tune related, and 9 times out of 10 it's not.
    PS got a data log of it cranking? RPM, inj pulse, etc?
    email=[email protected]
    Jul 2011
    15
    I have fuel pressure 58 psi. I would have to crank it again while scanning to check crank pulse.
    It doesn't pop or spit nor do you smell at any type of fuel. Im going to be bringing a friend over that I can check spark from the coils and injector pulse with a test light while the cars cranking.
    Doesnt the crank sensor send ignition signal when triggering the reluctor wheel? or was I just filled with wrong info in my head?
    Jul 2011
    15
    Question. I know you have to have some grounds on the motor but do all the grounds from the harness have to be on the heads or can some go to chassis? I think that might be and if it is boy do i deserve a smack in head.lol
    Jul 2011
    15
    Fixed the grounds to motor still no start. My scanner was working fine and now it keeps saying unable to locate vcm and the mpvi controller blinks busy.
    Apr 2009
    613
    More times than I can count people with swapped cars don't power the coils/injectors while the key is in the crank position. You need power to them key on and key cranking. Check that first.
    1997 Trans Am WS6 - LS1 swap - TR224 - Pacesetter Longtubes - Yank SS3600
    - 3.42 Moser 12 bolt - Wilwood Brakes - HP Tuners tuned - P1SC-1 Procharger
    Jul 2011
    15
    Quote Originally Posted by flame View Post
    Did that already, no spark.
    Sep 2010
    1,303
    Quote Originally Posted by Google View Post
    +1 and would like to add.... The pcm is missing a ground or power..
    Jul 2011
    15
    Is that causing no spark? if so plz tell me which power and ground pin I should follow. 2004 GTO PCM. Really appriciate the help guys.
