Results 1 to 16 of 16
Thread: 02's stuck at 450mv and no fuel trims, whats going on?
    Dec 2006
    25
    Hooked the scanner up to the car today and 02's are stuck at .450 and there are no fuel trim readings?
    Just finished a heads and cam swap on 99 LS1 motor. Grounds are all connected, everything is plugged in, just seems like it wont come out of open loop. When using VCM controls to command closed loop the car goes rich and dies.
    Anyone have any ideas?
    Feb 2009
    1,931
    you have stft disabled
    Dec 2006
    25
    enabled them and reloaded the tune, no change, so I swapped in a good working O2 and still no change. thanks for the quick reply tho.
    Sep 2009
    346
    I would think even if STFT was disabled and your in OL, you would still have o2 voltage variances being scanned if they are still in the exhaust stream and are plugged in.
    Flat line to me means the o2s are not reporting or not plugged in.
    Nov 2008
    Germany
    65
    Have you messed with the o2 switchpoints?
    5BA8
    3,253
    If they're stuck at 450mv, give or take a few, they're disconnected. Maybe not unplugged, but an issue with the connection. Unplug them and you'll see the same values.
    email=[email protected]
    Dec 2006
    25
    This was correct... there was a problem in the harness, and has been resolved, thanks everyone!
    Aug 2009
    Calibrating
    3,373
    Ran into this issue with a car today, told the customer to unplug the 02's and we had the same issue. It has to be in the harness, will post up as soon as we find something.
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    May 2013
    4
    Ben Charles, Umbrae, Did you ever solve your problems?? What was it? Have the exact same problem now.
    Aug 2009
    Calibrating
    3,373
    02 is either bad, wire burnt on the exhaust, 02's not plugged in. If they stay around 450 constantly its b/c the computer is not seeing them.
    14 Gen 5 Viper
    Advanced Tuner Pro Street's Avatar
    806
    244
    I am having the same problem! Anyone figure this out?
    2018 GMC Denali A8 6.2L
    2016 CTS-V
    2016 C7 Z06 A8
    2016 C7 Z06/Z07 A8 vert
    2015 Chevy SS 6.2 LS3 A6
    1996 Impala SS LT1 CAI
    1995 Chevy 1500 5.3 CAI Z06 cam
    1957 Chevy vert
    May 2013
    4
    Quote Originally Posted by Pro Street View Post
    Hi,
    I think I solved it even though I havn't really tried it for any period of time yet. My problem was totaly different, had a bad connection in one of the pinks going to the driver side injector and coil bank. Made the engine run on 4cyl and this kept throwing different codes and o2 sensors didn't get readings. So my advice is that if you get any other codes persue those first.
    Best Regards Axel
    806
    244
    Fixed it! Called the guy that made my harness and supplied my pcm. He said I had the wrong O2's. Told me the one's to get and it is working great now!!!
    2016 CTS-V
    2016 C7 Z06 A8
    1957 Chevy vert
    Aug 2009
    Calibrating
    3,373
    Wouldn't happen to be a PSI harness would it?
    14 Gen 5 Viper
    806
    244
    No it is a Speartech.
    2016 CTS-V
    2016 C7 Z06 A8
    1957 Chevy vert
    Apr 2022
    10
    Hi..i have the same promplem.which is the harness promplem?
