Results 1 to 4 of 4
Thread: making a yank 3600 stall streetable
    Tuner in Training quasarblue97's Avatar
    May 2011
    22
    Im lost fellows, can anyone help me out here. First dive into transmission tuning. Convertor is a yank 3600, trans is a 4l60e from monster, and the motor is a 383 lt1 running 24x from efi connection and an ls1 pcm conversion
    Advanced Tuner 69lt1bird's Avatar
    Oct 2007
    983
    Go here and open the Transmission Shift Rate file, this will get you going.
    http://ls1tuningguide.com/tuninghelpfiles.php
    If run a 4000 FTI stall with no issues.
    Free HP Tuners Beginners Tuning Guide
    LS1 Tuning Guide
    Michigan Snowmobiler
    1969 Firebird: 11.67@114 [email protected] 1/8 1.70 60 ft. EPS cam 234/246 .602.606 114+3, 6.0 LQ4, L92 heads milled 10.5:1, Ported L76 intake, ported 90mm Holley TB, 100mm MAF, FIC Custom injectors, Hooker LT, PYPES dual exhaust with an X pipe, 4L65e with all of the good parts inside, FTI 4000 RPM Stall, 12 bolt with 3.73 gears. HP Tuner tuned by me
    May 2011
    22
    cool deal, easy enough to use. Do I use the same map for all 4 (normal cruise hot and performance)
    Oct 2007
    983
    I did but you could experiment to see what it will do for you.
    LS1 Tuning Guide
