08 Tbss Awd
Just bought a 08 TBSS AWD, Want to tweak the trans for Longevity(since they are fragile) and Maybe alittle Fuel Mileage. What does everyone recommend? Anyone have a tune made up I can grab the settings off of?
nobody will give you tune files...and if you get one DONT COPY them.
only use them for referance because it may not be the same set up as your vehicle. besides you will never learn that way!
good luck
First, install a Corvette 2-4 servo. Then tune the shift pressures, shift points & TCC duty cycle tables. I also halve the upshift torque management tables & zero the downshift torque management table.
Russ Kemp
