Originally Posted by
ZJM861
I just bought a 2000 e46 for 3 reasons. 1- I realy like the body style. 2 - LS swap. 3- Priced right.
Getting the engine/trans in - dont expepct problems
Getting the engine to run - no problem
Getting the dang cluster to operate - huge problem
The dang e46 clusters uses can bus to operate the mph, rpm, temp sensor.
Is there a module that can do such a thing? If so what would that thing be called? I took the cluster apart to see if i could possiblly hard wire the tach signal and vss signal.. and dang there is so much going on which translates to I'd ruin the cluster if I even think twice about doing something to it...
Im a master tech at a bmw dealership and i will talk with the field service engineer and see if he can give me contact to ask about maybe hardwiring it..
any info on the GM class2 to BMW can bus module?
clint
