Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Thread: zr1 map sensor
    Feb 2008
    Pittsburgh PA
    112
    zr1 map sensor
    is this worth it to add to a car if your only planning on running below 10psi...how about over 10psi? Also how does one set it up in hptuners?
    2010 Camaro SS LS3 - Heads, Cam, Whipple 11psi 756whp 663wtq 93 and meth
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,860
    You should use one regardless of how much boost you are running. Search the forum for 12592525 and you'll find the info you need.
    http://www.dsxtuning.com
    Just say no to bull s***.
    Feb 2008
    Pittsburgh PA
    112
    thanks dsteck
    Aug 2011
    VA
    39
    Will a ZR1 MAP work in a 2011 Camaro ss? If so how do I go about tuning my car for that sensor with HPtuner?
    Mar 2008
    St. Louis, MO
    4,860
    The LS9 sensor is a direct drop in. Plug the sensor in, then just change the linear an offset values under Engine Diagnostics -> Airflow.
    Aug 2011
    VA
    39
    thanks for the reply. can you tell me how i need to go about the new tune, how do i figure out what i need to put in, what do i need to caculate,or where to start? thanks for the help!!
    Aug 2011
    VA
    39
    the numbers thats in my tune now are
    map sensor linear 128.13 kpa
    map sensor offset -0.31 kpa
    so how do i caculate them numbers to get the numbers i need so my car will run again? thanks again!
    Mar 2008
    St. Louis, MO
    4,860
    Search the forum for 12592525. There's a thread with the values.
    Aug 2011
    VA
    39
    is this what im looking for?
    linear 312.50
    offset -11.25
    if so thanks very much if not ill keep looking
    thanks for your help!
    Mar 2008
    St. Louis, MO
    4,860
    Yes.
    Aug 2011
    VA
    39
    thanks my car is running again
    now its ready for the tune
    thanks again!!
    and just curious how do you come up with them numbers?
    Mar 2008
    St. Louis, MO
    4,860
    They're taken straight from a ZR1 tune file.
    Jun 2008
    Charleston, SC
    969
    dave must be a republican! teach to fish rather than give fish for free..
    Aug 2011
    VA
    39
    oh ok
    Aug 2011
    VA
    39
    you seem to know the answer to all the questions i have so im going to ask 1 more thing,
    how do i set the pid up to log the boost with the zr1 map sensor on my scanner what i had in there was totally wrong now? do i get 1 more help line
    Jun 2008
    Charleston, SC
    969
    open scanner up, press F1, search Boost..
    Aug 2011
    VA
    39
    Quote Originally Posted by carlrx7 View Post
    thats what i did and its totally messed up now i put in what the help said to put in and when i scan its saying like 80to90 psi boost so thats not helping? i was closer with what i had in to start with and when i changed it i didnt write down what i had in there before so im back 2 square 1
    Jun 2008
    Charleston, SC
    969
    this is what i use.
    make sure to add the baro pid to the table
    ([SENS.30]-[PID.51])/6.9
    Aug 2011
    VA
    39
    this is what i use.
    thanks ill try that.
    Jul 2006
    403
    baro is your map sensor reading at acc on, engine off.. Unless there actually is a baro sensor.. I'd rather calculate boost by MAP minus average (seasonal) atmospheric pressure.. Then again, I have an E40 and lose logging speed for each additional pid.. gotta save those bytes..
    2006 Trailblazer SS - Stalled, Cammed, Tuned, Turbo'd, Built, and Stroked.
    Runs on cash, blood, sweat, and tears...... and 93 octane.
    2007 Cadillac STS-V - Stock.
