Results 1 to 6 of 6
Thread: Fuel Injector Table Help
    Tuner in Training cornerburner27's Avatar
    Feb 2011
    28
    I am trying to put the right injector data into the tune for my new setup. I am using a base 00' Camaro tune since that is the car it is for, and modifying it. I am using Bosch 39lb/hour fuel injectors which are obviously larger than stock. I am trying to transfer the fuel injector table from a more modern GM vehicle that uses these injectors over to my f-body tune. A few problems. First off, I have done a bunch of reading and it still seems a little unclear what cars exactly use these injectors. I do believe the G8 GXP and even the Z06's use these injectors. One of the major problems that I see is when I compare my f-body tune to other newer cars such as the G8 or Corvette. The F-Body tune uses the parameters of Flow Rate v.s. KPa for the injectors whereas the newer cars use Flow Rate v.s. Pressure (psi). If it is possible to transfer the injector data from one of these newer cars to my tune, is it a matter of just converting from KPa to psi, or is there more to it to get the proper table? Also, are there multiple tables involved in altering a tune for larger injectors or just this main table?
    Injector Reference:
    Bosch 0 280 158 051 (0280158051)
    GM# 12576341
    "Lotta people go through life doing things badly. Racing's important to men who do it well. When you're racing, it's life. Anything that happens before or after is just waiting."
    -Steve McQueen, Le Mans
    Advanced Tuner jakebdb56's Avatar
    Oct 2006
    Houston, TX
    646
    They're 41.7lb LS7 injectors... So, at 58psi they flow 41.7 lbs/hr. You can use this spreadsheet to help create the injector flow rate, http://www.marcintology.com/tuning/injectors.xls
    Here's what it should be...
    41.7007354 41.96062703 42.21891885 42.47564004 42.73081891 42.98448293 43.23665876 43.48737229 43.73664867 43.98451233 44.23098702 44.47609584 44.71986124 44.96230507 45.2034486 45.44331252 45.681917
    It is possible to derive the correct flow rate from the GenIV data. The delta pressure is rail pressure, so once you know what the flow is at 58psi, you can translate that to this IFR spreadsheet for GenIII vehicles. As for minimum pulsewidth and offsets, you'll have to download say a 2008 Z06 tune to see what those values are and translate them to the format in which you're working with.
    '20 AT4
    '01 Suburban 2500 Dad Wagon
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,859
    I've posted the refitted data for LS1 PCMs... If you hunt the Gen 3 forum, you'll find it.
    http://www.dsxtuning.com
    Just say no to bull s***.
    Advanced Tuner 69lt1bird's Avatar
    Oct 2007
    983
    I have it stored here for safe keeping.
    http://ls1tuningguide.com/tuninghelpfiles.php Bottom of page.
    Free HP Tuners Beginners Tuning Guide
    LS1 Tuning Guide
    Michigan Snowmobiler
    1969 Firebird: 11.67@114 [email protected] 1/8 1.70 60 ft. EPS cam 234/246 .602.606 114+3, 6.0 LQ4, L92 heads milled 10.5:1, Ported L76 intake, ported 90mm Holley TB, 100mm MAF, FIC Custom injectors, Hooker LT, PYPES dual exhaust with an X pipe, 4L65e with all of the good parts inside, FTI 4000 RPM Stall, 12 bolt with 3.73 gears. HP Tuner tuned by me
    Oct 2006
    Houston, TX
    646
    Quote Originally Posted by 69lt1bird View Post
    nice!
    '20 AT4
    Feb 2011
    28
    Quote Originally Posted by jakebdb56 View Post
    Great information! Thank you. I've still been surprised at how many different values I've seen these injectors listed at (kind of frustrating).
    Also, thank you 69lt1bird (Awesome tables) and DSteck for your input.
    I'm still a little uncertain that I understand the full range of tune modifications that need to occur for upgrading to larger injectors. So there is the Flow Rate v.s MAP table and the Injector Offset v.s. Voltage.... but what other tables must be modified as well? Do these 2 tables really control the majority of the injector function regarding different load, airflow, and rpm conditions? What about the Short Pulse Limit, Short Pulse and Min Pulse tables?
    Again, thanks for the help guys. Despite doing lots of reading, I still find myself with many questions... many which might seem rather basic.
