I am trying to put the right injector data into the tune for my new setup. I am using a base 00' Camaro tune since that is the car it is for, and modifying it. I am using Bosch 39lb/hour fuel injectors which are obviously larger than stock. I am trying to transfer the fuel injector table from a more modern GM vehicle that uses these injectors over to my f-body tune. A few problems. First off, I have done a bunch of reading and it still seems a little unclear what cars exactly use these injectors. I do believe the G8 GXP and even the Z06's use these injectors. One of the major problems that I see is when I compare my f-body tune to other newer cars such as the G8 or Corvette. The F-Body tune uses the parameters of Flow Rate v.s. KPa for the injectors whereas the newer cars use Flow Rate v.s. Pressure (psi). If it is possible to transfer the injector data from one of these newer cars to my tune, is it a matter of just converting from KPa to psi, or is there more to it to get the proper table? Also, are there multiple tables involved in altering a tune for larger injectors or just this main table?
Injector Reference:
Bosch 0 280 158 051 (0280158051)
GM# 12576341
