Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: 98 VCM able to go on SD to tune VE?
    Dec 2010
    Fort Worth, Tx
    104
    I am following 69lt1bird write up to tune the VE table on my 98 formula but the PCM is not wanting to accept the file and its bringing an error code saying
    "file does not match VCM hardware"
    how can I fail the MAF and go onto SD in order to tune the VE alone? is this possible? Im attaching the tune I modified so you can see what I changed to go onto SD mode.
    also here is a screenshot of the error code on HPT
    Dec 2010
    Fort Worth, Tx
    104
    Can someone comment on this before I email support please.
    405
    2,326
    Looks like you are trying to write a 99 F-body file to a 98 PCM. (you said it is a 98 Formula) You can't do that.
    Dec 2010
    Fort Worth, Tx
    104
    How can you tell it's a 99 file? I used the same file I had from it previously and turned off maf. Cot. Ltft stft etc.... Where do you see that?
    405
    2,326
    Dec 2010
    Fort Worth, Tx
    104
    geeez man, I did not see that, I think I have messed them up a little bit when choosing a different file.
    Ill copy entire and modify that one so I can do the VE tuning., Good catch, I appreciate it much.
    Ill update this as I do the VE tuning
    Dec 2010
    Fort Worth, Tx
    104
    ok now I have that going I loaded the new parameters to be on SD only to tune the VE but the darn scanner does not register my VE AFR error%
    can someone look at the cfg and see if anything is left out please.
    I am using a NGK AFX WB and thought to have all parameters where they need to be. Also uploaded the tune....the car runs super rich with how the VE is set up now. AFR is 10:1 at idle, I want to get this dialed but my scanner is not cooperating....help on this one please. Im learning as I go.
    thanks
    David
    Aug 2006
    5BA8
    3,253
    Doesn't look like you have your WB in there. Need to put that in the EIO inputs down at the bottom.
    EFI specialist
    email=[email protected]
    Dec 2010
    Fort Worth, Tx
    104
    how come I can see it on my end. its on the IEO #1 input. as NGK AFX WB...do you not see it? when I am logging I am able to see the AFR from the WB but the histogram dont load.
    Dec 2010
    Fort Worth, Tx
    104
    none of the 3 VE AFR histograms load at all. not even the VE O2 sensors one.
    Advanced Tuner robbyredneck's Avatar
    Jan 2010
    fingerlakes ny
    356
    when you see your wideband on the scanner is it reading in afr or lambda? your trying to to plot sensors instead of pids.
    you want to plot
    100*(wideband-commanded afr)/commanded afr
    this equals measured afr vs commanded i.e. afr error in %
    make sure you have all in your table. as i am sure you have read. your getting closer and now you see the importance of the allmighty scanner. post a scan so i can see how your config reads it. i would suggest you use lambda but thats up to you.
    04 6.0 silvy china turbo
    87 gn
    03 stroker evo ww
    00 ss camaro
    Dec 2010
    Fort Worth, Tx
    104
    im posting the latest scan I just did. One thing I also noticed is that the histograms are only recording 20 Kpa, even though the car is running at 60 kpa....here is the scan so you can look at and see what you can spot.
    I am not sure why is not plotting the data at the correct parameters.
    i hope we can figure this out by tomorrow to work on the VE calibration.
    I got the car to idle a little better but it is pig rich at most all RPMs on this VE settings.
    also one more question: how do you tune the VE on the 4000-6800 RPM range? same as on the low end....just getting on it? wouldnt that trip PE mode?
    im learning a lot as I do this. I see how this works but cant get the darn scanner to cooperate with me
    Senior Tuner Russ K's Avatar
    Dec 2005
    Regina, Sask.
    4,214
    Delete the Manifold Vacuum pid from the table display, and replace it with the Manifold Absolute Pressure (SAE) (Kpa) pid.
    Russ Kemp
    Dec 2010
    Fort Worth, Tx
    104
    im going to go try this out tonight....I think this is it Russ....thanks a lot for looking at it.
    now what do people usually do to calibrate the VE? do I go drive and hit as many cells as possible? even on the higher RPMs?
    Advanced Tuner blownbluez06's Avatar
    Jan 2008
    Forney, TX
    982
    Yes. I call it painting the VE. Vary your throttle throughout the entire RPM range as best you can, starting with # cell hits =0 then continue increasing the # cell hits and do more "painting" to fine tune it. After getting all of the low throttle data written, I also set a plot filter in the histo to prevent any decel data from hitting. [SENS.90]>18%
    Choose whatever % throttle you like to prevent decel data from hitting.
    Hsquared racing engines RHS 427, Procharger F2, Moran Billet Atomizer injectors, Alky Control,Mast LS7 heads, Nitrous outlet kit,Tilton quad disc clutch, DSS shaft, RKT56 ZR1 trans, RPM Quaife diff. Built and tuned by yours truly.
    Jan 2010
    fingerlakes ny
    356
    it's ok if it hits pe. i am confused as to why this was once considered a no-no . maybe old versions of hptuners did'nt have the ability to plot commanded data and then paste special, dunno. but if you have 12.5afr and that's what your commanding, you have zero error. if you take the pe or be factor out, you still have zero error.
    87 gn
    03 stroker evo ww
    00 ss camaro
    Dec 2010
    Fort Worth, Tx
    104
    cool, it seems lke its working good. I have been driving part throttle under 4000 rpms now I need to go out and do the higher end of the curve...
    how do I put the filter in? where at?
    Jul 2004
    1,579
    Quote Originally Posted by robbyredneck View Post
    That was because Fuel Trims were used to adjust the MAF/VE, hence no correction at WOT/PE ... or if the fuel trims were positive, it would add fuel. This was before wideband (or better yet Inputs) were developed.
    When we fixed your PCM we could have loaded a SD tune for you.
    I will take a look at your logs
    Jan 2010
    fingerlakes ny
    356
    Quote Originally Posted by 12secSS View Post
    thanks
    87 gn
    03 stroker evo ww
    00 ss camaro
