Originally Posted by
Jp Tech
Hello I have done a swap a few months a go and a code for p2534 keeps poping up have checked bat voltage and it ok 12 +- volts and when running 13.6 volts
but have deleated the code set to the 3 error and un checked the SES block IM missing some thing .
I have my stand alone harness I made and using the starter realy of my 2003 tahoe hooked up to key pul wire any help
new engine 2008 escalade with 6.2l 6l8oe
and the tahoe is a 2003 TAHOE USING THE ORIGINAL SWITCH
i have deleated the code unit will not CLEAR CODE KEEP POPPING UP
FIXED MY PROBLEM
I HAD MADE MY OWN HARNESS STAND ALONE HARNESS THEN I RAN ALLL MY POWER OFF THE SAME REALY
CODE P2534 THAT IS Ignition Switch Run/Start Position Circuit Low
so u used the yellow wire to the Ecm power relay cuircut and powered my pink 12 and D blue pin 6
