If it is asking for 2 more credits when you go to do a write, it is probably a custom operating system or you did not license it the first time. It is not usually recommended to write a file form the repository to your car. If you want to try the settings in your file, you are better off opening it in the compare function and copying the differances across. This will only cost you the initial 2 credits for your car.
Is the 2 bar SD a custom operating system? Thats what im trying to download. I havent paid the 2 extra credits for the 2 bar SD. Could that be why?
Got it. so if i would've just used the credits to go 2 bar SD and compared the files instead of buying the repository tune. Would that have worked?
Never flash a downloaded tune or something other then your own tune file. Always do a compare and copy over the changes. Many issue can arise from this bad practice.
