Results 1 to 9 of 9
Thread: Regular version VS Beta ?
    Oct 2010
    9
    are there more perameters in the beta version. Which is better in your opinions.
    Scott (Retired Navy)
    Paralyzed Triathlete
    2010 Camaro 12.35 110.73 1.65 60ft
    Mongillo Motors
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,247
    Here is the email I send out with the beta, so to say it has a few new features/tables/os support is an understatement
    This beta adds several new features for several platforms
    Adds read support for most 2003-2006 NGC3 Dodge, Chrysler & Jeep platforms, we ask that you read as many of these vehicles and send us the .hpt file and an infolog while connected to each.
    Adds support for interfaces starting with 116xxxxxxx
    Firmware update for SPI chip id conflict
    All platforms receive
    New Editor code
    New Scanner code with ability to scan most late model Chrysler/Dodge/Jeep applications
    Net Framework 4.0 standards
    Net Framework checks removed
    Multi vehicle upgrade credit bug fixed
    Fixed Spark table axes for RXAQ6BA ford strategy
    Added read support for 97 Cutlass V6
    Added read support for 2009 Ford Fseries Strategy TENF1
    E67 code fix
    New operating systems supported
    L4
    16253010 16259676 12225336 12206016 9382944
    9364978 12223048 9365314 9364968 9356822
    16254760 16254761 16267102 16254731 12578877
    9387547 12218880 12205378 9353697 9383067
    9356827 9373182 9365340 12580032 9387552
    1220464
    P11
    12583785 12218881
    P12
    12597424 12607148
    97 V6
    16257531 16253031 16243827 16254062
    16265838 16252926
    P04
    9374770 9352742 9389353 9352757
    12218400 12223490 12578500 12223490
    12201687 12618883 9376662 9389259
    12573407 12584933 12226103 12221348
    12218171 12203659 12211256 12201870
    9389700 9389351 12223440 12211252
    12596603 12211496 12218411 12211488
    12223436 12618881 9384035 12205332
    12201881 9389680 12213452 9352617
    12618861 9367747 12218860
    P05
    12581052 12619744 12635879
    98 LS1 V8
    9355168
    P59
    12578128
    E37
    12610011 12618032 12635865 12628829
    12630187 12628960 12628961 12635399
    12639473
    E38
    12635859 12636005 12635863 12639835
    12628982 12639270 12630465
    E55
    55573067 55573114 12623990 12595778
    92179468
    E67
    12636036 12639469 12635904 19211212
    12638778 12618044 12632176 12639299
    E69
    12629314 12634286
    T43
    24253414 24254909 24252573 24249179
    24257135
    T42
    24243902 24252617 24252956 24243356
    A40
    15878459 25982141 24256578 24256580
    Ford
    HABND HABS2 HACCE HACCD
    HADCD HADCE HADCK HAEDG
    HAEDD HAEDH HAAMC HAAMF
    HAAMG HACCK HACH3 HAAS2
    HAAS4 HAAP9 HACHD HACHF
    FBMR1 HACE8 HACE3 HAAT0
    HAAT2 FPBF2 FBBT0 FBCE0
    HAFDF HAFDJ HAFFA TENF1
    FPBX1 FBCE2 FEBF1 HAEE4
    FOAR0 OKCM7 FPASB TADP6
    FBRE7 FBLF2 FSAEA HACF0
    HAEE3 FBMMB HAAO8 FOASB
    FBHR2
    Vortec
    16258745
    Dodge
    05030232AE
    P12 pcm’s receive
    To and from cobalt ss/sc unable to connect error fix
    E77/E69 pcm's receive
    Several overboost/underboost condition diagnositic test tables and constants
    Map sensor tables
    Wastegate & BOV tables
    Fuel pressure tables
    Injector tables
    Fan tables
    Spark tables
    512kb & 1024kb LS1 platforms received
    Options matrix
    Platform type switch
    Fan recirc switch
    TPS High & Low fail constants
    About a dozen new rolling idle tables and constants
    IAT Scalar table
    512kb LS1 pcm’s received
    Cranking spark table
    E38 & E67 pcm’s received
    Roughly 50 new tables described here http://www.hptuners.com/forum/showthread.php?t=28498
    The following E38 os id’s received 1-2.5 bar vcm enhancement:
    12612381 12639270 12633056 12635863 12605732 12614676 12612281
    12617631 12628990 12624402 12633016
    E38 Starter check patch applied to:
    12614676 12614088 12630501
    E37 Starter check patch applied to:
    12618032 12618044 12610011
    E38 P2101 Throttle parameters added for
    12617631
    All E38 operating systems receive the following speed limiter constants
    Speed Limiter 4WD Low
    Speed Limiter Comms Fail
    Speed Limiter Steering Fail
    Speed Limiter Minimum
    Speed Limiter ETC Fail
    E67 OS id 19211212 received 1-2.5 bar vcm enhancement addition
    E67 pcm's can now perform write calibration only without error
    All E40 os’s receive cranking spark table
    E40 os’s 12596734 & 12596660 received
    P2101 Throttle tolerance params
    T43 TCM's received a major 150+ table update including TM & TCC lockup tables requested
    E37 support released
    GMPP E67 pcm support released
    GMPP EROD pcm support released
    2009+ Allison TCM support released
    2010-11 Camaro V8 ECM/TCM support released
    2009-11 Corvette ECM/TCM support released
    2009-10 Mustang V8 ECM support released
    2009-10 Savana/Express V8 gas support released
    2009 G8 V8 support released
    2002-2011 Ford BA, BF & FG support released
    97-04 V6 pcm’s
    Received several open loop and injector tables added to all 700+ operating systems
    Ford credit licenses lowered to 2 credits for single vcm licenses
    Ford Scanner rate updates for faster scanning
    Fixed airflow table address in Aust. Ford operating systems HAEDG/HADCK
    Mar 2010
    16
    So this means the copy I just bought today, that says "Beta" is good, right?
    IOW - I was Supposed to be shipped the BETA version on CD from the vendor?
    Quote Originally Posted by RichmondZ16 View Post
    this does not sound right. the beta version is for testing, I dont think you can buy it, you would buy the latest version and ask support to send you the beta...
    Bill will give you the facts
    2003 Chevrolet Silverado SS
    L92 Heads/ L92 Truck Intake
    OBX LT Headers
    Custom Ridings 3200 Stall Converter/Built Trans
    6 Piston ZO6 Brakes/ 2 pc 15" Front rotors
    HP Tuners Support
    (foff667)
    28,247
    The newest batch of interfaces starting in 116xxxxx need the beta to function properly.
    Jun 2007
    Finland, Europe
    548
    Oh, but then this must mean we're nearing....something Bill doesn't want to hear one more time... :-)
    Advanced Tuner n0dih's Avatar
    Mar 2006
    Cherry Valley, IL
    391
    I gotta ask, when is 2.24 coming out? From what I gather there hasn't been a non beta release in years.
    http://www.hptuners.com/forum/showthread.php?t=5707
    Just asking...
    Jun 2007
    Finland, Europe
    548
    Quote Originally Posted by Pekka_Perkeles View Post
    One step closer....yep it is. Must be. Maybe? :-)
    Dec 2012
    Atlanta
    64
    Yeah I guess I`m gravedigging, but I also just received mine and it is 2.23 beta.
    So are you saying that I need the regular version AND the beta to support it, or I just need beta?
