I recently had to rebuild my engine bc the 5th and 7th piston ring lands broke off the piston bad. The engine builder said it was bc of heat and probably to much timing at WOT. Also maybe a lean condition.
I have the last WOT run and the current tune untouched since the accident. I want to make sure its safe to run before I granade my engine Again.
please make recommendations if I need to do some changes.
the thing that concerns me a little is that the AFR goes in the mid 15's on some spots and the timing at some points is in the 39* but I think that is ok at idle right.
I want to make sure the tune is safe for me to get on it and test out the new setup.
I changed the Torque Coverter from a 3600 to a 4000-4200 Circle D and a rebuilt engine 408 ci
