EDIT LOG/SCAN POSTED BELOW
I have gotten my turbo kit on my 99 trans am and about going to swap fuel systems and tune shortly. The car currently has a front mount 70mm turbo kit on a basically stock motor. Right now there is a 6-7lb spring in the tial wastegate and the fuel system consists of 60# injectors and dual 255 pumps (2nd will be on hobbs switch). I made this file as a startup and then based on logs, my wideband, boost and fuel pressure gauge I plan on dialing in the car.
Notes I have for this file, started with a stock file:
Modified High octane spark advance
-lowered overall top end high throttle timing, kept mid range throttle timing moderate
Low octane spark advance
-Lowered timing overall
-Flow rate vs KPA modified for 60# injectors
-Lowered hot PE Table Values
-Bumped PE Multiplyer to 1.2XX for AF in the 11’s
-Extended MAF airflow vs Output so 12000 = 512 g/sec
-Fans to stay on for 120 secconds when 200* +
-Lowered fan turn on temperatures
Is there anything that I missed in regards to tuning for the injectors? Do you guys see anything that seems out of wack or you would reccomend changing for my setup? I haven't touched the DTC's yet. I have tuned FI cars before but they were obd1 so this is my first stab doing it all through the computer.
Any input would be GREATLY appreciated!
