The absolute first order of business is to fix that misfire. I assume you have the 2.2L engine. They like to fry injectors (sidefeed style) especially if you're stuck with ethanol blended gasolines, real fast if you experiment mixing E85 in with your gas. Find out for certain though before buying an injector for around $200 a peice! You might want to run on the factory tune untill you fix the misfire, which I would also like to know the exact cause of once you figure it out. After that's squared away I'd be more than happy to give you a few pointers at least from a beginners perspective. Always feel free to post a copy of your tune and a scan log, in your case a log recorded right when it's misfiring. Helps to adress questions that may arise if people try to help. Also did you have the misfire before you tuned, right after you tuned, or quite a little while after you tuned your car?
