Having a difficult time
Im having a difficult time getting the MPG pid to work in the histograms. I can get it to look like its supposed to until i hit the record button, then it goes to this
and heres what it looks like right now sitting in the house
i tried to setup the pids on the table that werent there that should be logging for this custom pid to work, so i added like 3 things and when i would hit record it would shutdown vcm scanner.
ok well i figured it out i hope. Its updating and shows 0.0 at idle. I was trying to add pids that were already logging and i had to completely start over from a new slate. I created the pid, then added it to the histogram table #8, then added injector flow rate to the table (primary) and saved everything, then exited the scanner.
Restarted scanner and voila!!!!!!!! It works!!!
