Hello
Got my hp tuners tuning file up and running but can't get my aem to show a reading on the guage in the guages set up or log on the chart display. Must be something with my pid? I have t-tapped the red/blk wire going to my 3 wire a/c press sig. left the a/c sig plug unplugged and tapped the red/blk wire to go to the aem Uego. As far as I know thats the correct way to wire it. Under the chart configuration I have it enabled and labeled as a afr with a afr output, there is nothing for click to add pid, when I change that to a/c press and voltage output it changes all the labels like aem wideband and has a voltage measurement instead of afr. what gives? I could use a few screen shots of correct data in the config table.
thanks for the help guys!!!! last part I have to get ironed out!
