I now have a gms1 installed and i remember when it was stock 255kpa value was 23 psi. does anyone know if there is a new scaling for the new pressure sensor? and what are the values at boost for 23/24/25 psi?
You can log Boost Sensor Lo Res in the beta and select to display PSI or kPa in the scanner. It reads the 3 bar MAP in the lower CP. It will show a small positive value at cruise, (2-3 psi) but at WOT it's spot on for boost. The intake mani sensor still only reads to 255 kPa, or ~22.4 psig
is it a pid cause im not finding it for some reason?
Yes it is, it's in the recent beta.
Created the custom PID for charge pipe pressure as follows:
[PID.2338.PSI]-[PID.51.PSI]
or
Boost Sensor Lo Res - Barometric Pressure (SAE)
Called it Charge (psi)
Make sure you add both PID's to the table first.
ok i just cant read found it thanks!
NP, the PID's aren't in any particular order.
I'm curious if this would provide a different result than [PID.2338.PSI]-[PID.2340.PSI]?
Is there any difference between BARO Sensor and Barometric Pressure (SAE)?
The only reason I ask is that I didn't have Barometric Pressure in the list before my last logging session. Only BARO sensor was activated so I can't change the PID retroactively and see it in the log files.
Try it in a new log. I doubt it is off very much though.
