Just thought I would share a recent problem I had and the solution to it.
I installed a Yank 3600 stall converter and TCI flexplate in my cars 4l60e and immediately had issues with torque converter lockup. When cruising the converter would lock for a couple minutes and then unlock for a couple minutes, it seemed to be at random.
I played around with tcc apply speeds a bunch, but to no avail. The PCM was not picking up any DTC's on HP tuners or a Tech 2 (GM scan tool), so I ruled misfires out as a cause.......or so I thought. Long story short after beating my head against the wall I maxed out the misfire detection tables and tcc operation worked like it was supposed to. I really like having lockup when cruising.
I know others have come across this, especially in vehicles with cams, I just thought that since no misfires were detected it was not an issue. Anyways I hope that this helps anybody having issues with lockup after putting in a stall converter.
