Has anyone ever messed with the fuel gauge output on their vehicles? I have always been aggravated by the fact that the fuel gauge in my 04 truck doesn't read linearily. It stays on full for a while then moves on to half a tank rather quickly then below a half a tank it drops really fast. Its just aggravating. So I decided to mess with the settings in the fuel sender and gauge output tables. What I'm wondering is if I did it right. I took the gauge output table interpolated between 100 and 10 percent since it was not a linear curve. Then I took the primary volume gauge table and interpolated it between 0 and 100. I did the same in the primary volume table.
Now, what I'm wondering is if I did this right. I don't want to run out of gas on the side of the road because I messed it up. What has got me wondering is that I noticed that the tables seem to be reversed from what they should be. The description in the software of the primary volume and the primary volume gauge tables says that they are remaining fuel volume versus remaining fuel level from sender. But the data in those tables seems to be reversed. The remaining volume numbers are higher at the lower level indicators and decrease as the level indicators increase. So they are inverted. The gauge output table is the same way. The PWM value is higher at a lower gauge percentage and decreases as the gauge percentage increases.
Does anybody have an explanation for this? Also, did I scale the values in the correct manner? Thanks in advance for any info.
