Results 1 to 3 of 3
Thread: Injector swap
    Feb 2010
    34
    Injector swap
    I am swapping the injectors in my 2000 C/K truck with a 7.4L engine. What do i need to change in my tune besides the injector flow rate the stock injectors are 19.4lbs/ H and the new ones are 23.3lbs/H
    Tuning Addict WS6FirebirdTA00's Avatar
    Jan 2005
    Concord, NC
    7,897
    all the other injector parameters that are available also need to be set correctly.
    Sulski Performance Tuning
    2000 WS6 M6
    Old Setup: 480 rwhp 437 rwtq with 230/232 cam and a best of 7.17@98.47 w/1.58 60'
    New Setup: AFR heads, 11.6:1 CR, 90 mm ported FAST, Exo-Skel, 236/244 custom ground cam, QTP HVMC, EWP, GMMG, 9" w/4.11s
    Feb 2010
    34
    Here is my stock tune and my current tune. the injectors I put in are GM part number 25313185 and the specs i could find on there are lbs/H 23.3 cc/min 244.9 grams 176.1 43.5 psi
