Page 6 of 12 FirstFirst ... 2345678910 ... LastLast
Results 101 to 120 of 222
Thread: Please help find whats missing from my settings. Boosted 2.4l LE5
  1. #101
    Tuner SlvrSky07's Avatar
    Feb 2011
    La Crosse, WI
    160
    Lol no way for that one.. Ill mess around with it and see what I come up with in the spring
  2. #102
    Jul 2010
    371
    well you could turn decel cut off, or make it engage later if the pcm will let you. but say bye bye to 4 mpg's if you turn decel cut off.
    1994 Mazda Miata turbo, aero, hoosiers Class=SSM
    Take my drop box referral and we both get an extra 250 Mb free!
  3. #103
    Feb 2011
    La Crosse, WI
    160
    Why would having it give gas when you are basicly engine braking be more helpful? All my older cars just go full lean until idle rpm and they work fine.
  4. #104
    Jul 2010
    371
    You've got a ton of un burnt fuel in the exhaust from being so rich in boost, exhaust it hot, but the mixture in the exhaust is too rich to light off. Decel cut come sin and introduces a bunch of air, and bam mixture becomes lean enough to light off and does.
  5. #105
    Feb 2011
    La Crosse, WI
    160
    ah well maybe ill just have to deal...
  6. #106
    Tuner thebucky84's Avatar
    Sep 2009
    SoCal
    146
    So I don't want to make a new thread about some LE5 tuning. Anyways, how is the tuning going? I'm thinking of throwing a turbo on a LE5. Are the ECU's for the 2.4 any good to tune? Just trying to see if it's worth building.
    2011 CTS-V Coupe
    - 1993 Mazda RX7
    *The most powerful designs are always the result of a continuous process of simplification and refinement.*
  7. #107
    Feb 2011
    La Crosse, WI
    160
    Tuning is just about done. A little more fine tuning in the spring and possibly a dyno tune. They are just as easy as most to tune. From what I read they are the same as the Corvette ecu. I turbocharged my le5 sky. Wish you the best of luck.
  8. #108
    Sep 2009
    SoCal
    146
    Are there any updates on adjusting the cams for the LE5 ecu?
    2011 CTS-V Coupe
    - 1993 Mazda RX7
  9. #109
    Feb 2011
    La Crosse, WI
    160
    I haven't changed anything for the cam timing or vvt. I'm interested in seeing if there's a way to gain power by changing vvt settings.
  10. #110
    Sep 2009
    SoCal
    146
    reason I am asking is that I am in a pickle between building a LNF or LE5 RWD application. The LE5 parts, especially block, is very easy to find compared to the LNF. If I can properly tune a fully built LE5, with cams, then I probably will. But if I cant adjust the upgraded cams them building a LE5 will be a waste of my time.
    2011 CTS-V Coupe
    - 1993 Mazda RX7
  11. #111
    Feb 2011
    La Crosse, WI
    160
    I'm not sure on that part. Some of the senior tuners would know. I'm sure its been done before though. If you need help with anything else let me know.
  12. #112
    Advanced Tuner laser_racer's Avatar
    Jul 2009
    league city tx
    461
    I couldn't see why you wouldn't be able to tune for cams. Zzp sells them for the le5 and lnf just take little time to dial it in.
  13. #113
    Feb 2011
    La Crosse, WI
    160
    Hey everyone. I have been working on changing my car to run e-85. The car is dialed in correctly on gas and I have changed my stoich value to 9.765. The car runs a bit rich and I think Ill have to do some maf tuning. Id like to change it to lambda. Now I have set up 2 custom PIDs for commanded lambda and lambda error ( I think I have done them correctly). Now Ill have to change the LC-1 to output only lambda? and the finial question is tuning the maf. Does anything change in the way I tune for MAF high and low? Or am I missing a step?
  14. #114
    Feb 2011
    La Crosse, WI
    160
    Here is my config, log and tune. The E85 tune is the one I'm on now. The gasoline tune was done at the dyno previously.
  15. #115
    Feb 2011
    La Crosse, WI
    160
    I forgot to mention that I was unable to get into my LC-1 to change it to output just lambda. It is still on the same mode as it was for tuning gasoline afr.
  16. #116
    Jul 2010
    371
    Quote Originally Posted by SlvrSky07 View Post
    The LC1 outputs a voltage related to the lambda value the sensor is detecting. The gauge that comes with the cheap LC1 only displays afr in gasoline weighting. But you can have it show however the you want in hp tuners, you just have to change how the custom pid is setup.
  17. #117
    Feb 2011
    La Crosse, WI
    160
    Could you please take a look at my logs and config to see if I have something messed up?
  18. #118
    Jul 2010
    371
    Dont have HPT on this computer. BUT if you didnt touch the output from the wideband at all theoretically all you should have needed to do was change your voltage offset, the number you add at the end of the pid equation (I believe that its 10 in the walk through for making the wideband pid). It would need to become like .68027, if 10 was the previous minimum afr you were reading with hpt.
  19. #119
    Feb 2011
    La Crosse, WI
    160
    This is my current tune its going so far so good
  20. #120
    So how's the e-tune going? I'm in the process of trying to dial in an e85 tune on my buddy's turbod LE5 as well. I gotta tell ya, it's honestly a bid daunting seeing all these tables seeing as how I've only really only ever tuning LNF's.... lol
    What turbo are you running btw, and are you still on 42's?? Any advice would be greatly appreciated as well..
