Results 1 to 8 of 8
Thread: 2010 2500HD trans tuning
    There any guides/FAQs on tuning the '10 2500HD trucks? I was looking to tinker with mine a bit, reduce the torque management some and speed up the shifts.
    What?
    Looks like spam.
    Tuner in Training 08RED2500HD's Avatar
    Jun 2011
    Miami,FL
    40
    As far as facts and guides. I have none. I can tell you though that i dropped shift times to 0 and increased trans line pressure. Also disabled all TM and its a completely different truck. Oh and got rid of the throttle delay
    Tuner in Training cdb09g8gt's Avatar
    Sep 2009
    Johnstown, PA
    19
    Quote Originally Posted by 08RED2500HD View Post
    What did you do to eliminate the throttle delay?
    2010 GMC Sierra 1500 Crew Cab SLE Pure Silver-Hauls family and stuff-New Hot Rod
    2004 Chevrolet Silverado 1500 Crew Cab 5.3L-SOLD
    2009 Pontiac G8 GT 6.0L-Hauls ass-SOLD
    1995 Chevrolet Camaro Z28-Hauls serious ass-SOLD
    2002 Saturn SL2 1.9L-Hauls groceries, white like most other appliances
    You Tube Channel: http://www.youtube.com/user/roadracing3?feature=mhum
    Under Engine/Airflow/Electronic Throttle - Area Rate Limits - Opening Rate - Set all but Reverse to 100
    Sep 2009
    Johnstown, PA
    19
    Thank You, I'll check it out.
    Potential Tuner ripmf666's Avatar
    Sep 2011
    From Md but in KcMo for now til we move back.
    5
    With the Allison you can not increase line pressure with tuning. You have to go inside the trans and do the mods. Also you do not want to remove defuel or TM you will end up with a tie up on a shift.
    Devil Girl 2006 2500HD LBZ Ex-Cab 4x4
    EFI Live tuned by IdahoRob,MPI twins intalled by BigDipper,PPE dual cp3,PPE lift pump,BigDipper 30% injectors, BigDipper Trans Precision ML converter.
    Alot Of thanks To George aka BigDipper
    [email protected]
    1979 Camaro Z28,400sbc bowtie block,Je blower piston,Lunati rods and crank,Brodix weldtech ported heads.J&W ultra Glide,J&W 5500 converter,With new mods should run in the mid 7's to low 8's @ 160+ area old setup at 3660lb went [email protected] on dot tires.
    Mar 2011
    10
    Does HPT support the a50 TCM?
