Results 1 to 5 of 5
Thread: C6 A6 shift modes
    C6 A6 shift modes
    I searched..... can anyone tell me what "Normal, A, B" represent? I know there is full auto, sport, and TUTD, somewhere there is cruise control as well.
    Thanks in Advance!
    bump?
    Feb 2007
    San Antonio, TX
    1,255
    Depending on the vehicle, Pattern A/B could consist of sport mode, the paddle shifters, ect. Some vehicles do not use both A/B. The G8 for example doesn't use Pattern B. I can't tell you which year/make/model uses which unfortunately.
    Recommend:
    Open NORMAL
    <This table adjusts the partial throttle up shifts as well as down shifts at varying throttle percentage.>
    Highlight all cells 0%-50%. + 2mph at a time until you reach your achieved driving style.
    Repeat same steps for Pattern A/B. Adjust as you see fit.
    Some like to have A/B more aggressive.
    Blend your changes into the remainder of the table 50%+ so your transitions are smooth.
    Janky Monkey Tuning
    Call or PM for tuning solutions.
    Cell 210-954-4985
    Wrench turning provided by 2 Tightwads Racing.
    Tune your own? Start here ----> Open Editor ---> Hit F1...READ!
    READ SOME MORE (Thank username 69Lt1bird): http://ls1tuningguide.com/
    Still lost? Consult a Pro!
    www.thetuningschool.com
    www.calibratedsuccess.com
    www.tunedbyfrost.com
    Advanced Tuner madvette08's Avatar
    Jan 2009
    Tampa, FL
    427
    Pattern Normal/A are Drive, Pattern B is Sport and the Tap Up/Tap Up Paddle Shifters have there own tables below Hot.
    Shift Pressures: Pattern X is Drive and Pattern Y is Sport and Paddle Shifters.
    Shift patterns Auto Shift Properties > General and look under Shift Pattern Type.
    Shift Pressures Patterns go to Auto Shift Properties > Shift Pressure and look under Pressure Pattern Select.
    Ian
    2008 Corvette A6 - Comp Cams 231/239 617/624 109 ICL 113 LSA, Patariot Extreme Dual Springs .660", Milled .30" Stock LS3 Heads, Mahle -4cc pistons, FTI 3600 Converter, 1 7/8 kooks cat-less 3 inch X-Pipe, air raid intake, ported TB, SLP Loudmouth I. 512hp/464tq
    2011 Ford Taurus SHO - stock with just a Tune
    Banned
    Apr 2011
    Usa
    36
    Quote Originally Posted by madvette08 View Post
    Ian
    I was looking for this too- thanks
