Page 1 of 2 12 LastLast
Results 1 to 20 of 30
Thread: Installing LS3 injectors in 2001 F-Body, need LS3 data
    Apr 2004
    Erie, PA
    464
    Question Installing LS3 injectors in 2001 F-Body, need LS3 data
    I'm installing a built LS3 into my 2001 Camaro SS M6 and I will be using LS3 injectors.
    Does anyone have the LS3 injector data to be used in an F-body application? I looked at a 2010 Camaro file and it's not the same as the older stuff.
    Any help is appreciated!
    Bill
    2001 Camaro SS M6 - 23,xxx Miles
    Huron Speed AC Turbo AC Kit - 6.0L 9.4CR, LS3 Heads, 226 232 115 lsa cam, Turbonetics 7575 1.15 AR Turbo
    10.98 @ 133 MPH on 9 lbs boost
    Advanced Tuner 69lt1bird's Avatar
    Oct 2007
    983
    Some one posted this once, I can't recall who it was.
    Free HP Tuners Beginners Tuning Guide
    LS1 Tuning Guide
    Michigan Snowmobiler
    1969 Firebird: 11.67@114 [email protected] 1/8 1.70 60 ft. EPS cam 234/246 .602.606 114+3, 6.0 LQ4, L92 heads milled 10.5:1, Ported L76 intake, ported 90mm Holley TB, 100mm MAF, FIC Custom injectors, Hooker LT, PYPES dual exhaust with an X pipe, 4L65e with all of the good parts inside, FTI 4000 RPM Stall, 12 bolt with 3.73 gears. HP Tuner tuned by me
    You should feel lucky, I had to search for months, and bug some really intelligent people, who did a lot of math work to get that data. You got it in under 30 minutes!
    Oct 2007
    983
    I put it up on my website so it can be someplace permanently.
    http://ls1tuningguide.com/tuninghelpfiles.php
    LS1 Tuning Guide
    Still no "Advanced LS1 GEN III Tuning Guide" yet ?
    C5-2000 MN6 LS2 block Tony Mamo FAST90+Ported LS2 TB 100mm MAF AFR 205 59cc CompCam 921 Yalla Terra G5X1 LG Pro Headers LG G2+T1 Chassie LG ducts MOVIT brakes - HPT&NGK AFX
    //Sweden
    Oct 2007
    983
    Sorry, nothing yet. I will be off work for two weeks for surgery, maybe that will give me time to do some more work on it.
    LS1 Tuning Guide
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,859
    That spreadsheet isn't quite accurate. I'll refit all the data from a 2010 Camaro later... Too lazy to write the Excel sheet to do it right now.
    http://www.dsxtuning.com
    Just say no to bull s***.
    Oct 2007
    983
    Thanks, I will repost the updated file on my site when you finish it.
    LS1 Tuning Guide
    Apr 2004
    Erie, PA
    464
    Thumbs up
    Thanks guys! Very much apreaciated!!!
    Sep 2008
    40
    Hey there,
    I am the creator of that sheet. I used it to put LS7 injectors in my LS1 with some custom adapters I made to acccomodate the height difference. So, the actual data in the sheet isn't from an LS3, but rather an LS3 "style" injector. The math and conversions should be correct, but the actual values may be different on the flow rate table due to the values being from an LS7 - 42 lb/hr injector. All it would take to make it correct is to find a stock LS3 .bin file with the injector data in it and copy it into the sheet. That's what the sheet was intended for anyways.
    If there are any other errors in the sheet, please let me know. I'll be more than happy to update it and correct it, but I couldn't find anything off when I originally made it.
    For the record, my truck that has the LS1 with the LS7 injectors runs and idle's like a champ from using this sheet.
    Thanks,
    Cody B.
    Mar 2008
    St. Louis, MO
    4,859
    I'm sure it runs fine, but being the picky perfectionist that I am, there is a better method to translate the data instead of interpolation into the LS1 format.
    Edit: Attached is an LS1 file with all the injector data entered in. This injector data was pulled from an LS7 file... yes, the 2010 Camaros have different numbers, but they are the same injectors.
    Apr 2004
    Erie, PA
    464
    Thumbs up
    Thanks so much!!!! So I only need the 3 tables that were changed then?
    The short pulse adder is WAY different than my stock 2001 file.
    What about MIN Injector Pulse and Default Injector Pulse? They can stay stock?
    Again thanks for everything!!!
    Bill
    Mar 2008
    St. Louis, MO
    4,859
    Short pulse adder is a characteristic of the injector itself... it has nothing to do with the car.
    Yes, default and minimum pulse are fine.
    Jun 2010
    559
    So i just bought some 42lb from an ls3, what i need to do is add 16.8 to my injector flow rate vs kpa vac, that gave me 42.2. Is how the tuning school show me (25.2-42=16.8). then copy the ls3 injector data to my offset vs volts vs vac.
    correct me if im wrong...
    Mar 2008
    St. Louis, MO
    4,859
    Quote Originally Posted by 02Ls1 View Post
    That is a dead wrong way to do it.
    Just take the data from the file I posted.
    Jun 2010
    559
    Ok. do i copy the the flow rate and the offset vs volts tables or theres another table i have to copy?
    Tuner in Training Tongboy's Avatar
    Jul 2011
    Portland, Oregon
    14
    Quote Originally Posted by oakley6575 View Post
    I know this is an old thread, but when you change injector data rom LS1 to LS3, what will that do to the tune? Will it mess with the VE table at all? Make it go lean or rich?
    VE is unchanged, the computer will use the different injector data to properly meter the fuel to fuel appropriately for the VE table and all the other parameters that come into play.
    as long as you aren't leaning out or something in your VE table up top changing injectors should not require any further tuning other than the injector data
    Read my BMW E36 M3 LS1 Swap Thread - ///Mullet - 12.8 @ 113 2.1 60'
    Tuner in Training TooMch's Avatar
    Mar 2007
    St. Louis, MO
    13
    This is an old thread (to mimic what a previous poster said and now it's even older) but the post I quoted concerns me. I was considering attending the tuning school. But the quoted post makes it seem like they are taking shortcuts.
    2004 Grand Prix GTP CompG, 2001 A4 3.42 Vert Vette
    Advanced Tuner oakley6575's Avatar
    Aug 2011
    421
    If i'm reading this correctly, are we trying to get the data from the ls3 injectors at 58 psi?
    2003 Chevy Silverado Daily Driver, 408 Iron Block,
    LS3 Heads/Intake, 231/239 114, 4L80e, Yank SST 3200.
    The LS3 injectors are rated at 58psi. The issue is that the tables from an LS3/7 don't carry over to the LS1 OS.
    94 BB Rx-7 02 LS1
