Interesting. I wouldn't waste a bunch of time on it if it gets involved, it's really a trivial problem.
I'm not seeing any changes in pedal vs. throttle mapping on the new damping tables, no matter what I change the 1 second delay is still there. The throttle will follow the pedal exactly until about 50%, then it lags behind pedal position until it's at 100%. I'm still not sure this is a super big problem because I just don't think it's wise to go from 0 to 100% in an instant anyway.
There is another issue that many of us have been trying to work around, it's an ignition timing issue. This is a huge issue, I'm betting every LNF tuner or vendor has this problem if they know it or not.
If you go full throttle from around 2000-2500rpm, at between 2800 to 3000rpm the ign timing will drop sometimes as much as 15*. If you go full throttle starting around 3000rpm, the ign timing drop will occur between 3800 to 4000rpm, and again, as much as a 15 degree drop. What this feels like when you're driving is a very sharp "hit" of power when the timing goes back up to desired, or what you've put in the tables. I'm sure most every LNF driver has felt this, and probably thought it was a boost spike, it's not. Instantly going from super retarded ign timing to 15* is a pretty big jolt of power.
I've worked around this in the past by manipulating the way the ECM calculates torque, making it think the torque is way too low sometimes results in the ign timing staying at desired without making this big drop. It's a backwards way of fixing the problem though, because we don't have control over whatever is making the timing dump. Believe me, I've tried every table we have in this LNF and nothing directly effects this issue. This issue is a huge deal, if you look at dyno charts from just about any vendor or tuner you will see a dip and then a jump in power. Most of the time it's just very hard to make power below 3k rpm because of this, that's why many vendors don't show dyno charts below 3k or even 4k rpms.
I'm guessing there's some other ign timing table that has direct control over this, like a torque management tip-in timing retard or some sort of overboost (?) triggered timing retard, or maybe piston protection timing retard? Changing what the ECM "thinks" the delivered torque is definitely has an effect on this, for instance if you go way higher on the "Optimum Spark" tables you can get rid of the timing drop, but only in 3rd, 4th and 5th gears, and not without raising other issues. Optimum Torque and Lambda Efficiency also has some effect on it, but again, not directly and not without bringing in other issues.
I'll post a couple screen shots of what I'm talking about, it should be pretty easy to see the timing drop, then jump back up to what is commanded in the tables. I'll also post a picture of 3rd gear with it gone, by manipulating the torque calculating tables, but again, it still does it in 1st and 2nd gears.
This is a frustrating one for me, and others too. Dave from DDM brought this up to me awhile back and I started to look back into it again. His exact words to me were, "Have you figured out why we have no ignition timing control under 3k rpms, or how to get control?" He also mentioned that every dyno chart he's seen from his competitors shows the same power drop, then surge.
You guys have done so much for us on this lately, I'm so happy to have more control over this ECM. If there's any way you can look into this I would say this is a pretty big issue that just about every LNF tuner and vendor deals with, or notices the power drop and surge and figures it's boost spike related.
Thanks Chris, and Bill!
John
This shows the drop...
This shows the timing going back to 22* (from 6* during the drop)...
This one shows that it will follow what's commanded in the ign timing tables if you manipulate the torque calculations drastically... (if you look to the left of the marker line you can see the timing did actually drop in the exact same spot it always does, but only 2 degrees this time instead of 15*)
Oh, BTW, these shots show the throttle lagging behind the pedal from 50% to 100%.
Thanks guys!
