I had to remove a bunch of timing from my stock tables after my head swap. Just wondering if this looks okay to everybody & if I need to worry about anything else at play here.
I had a lot of KR around the .52/2200 area, so I had to remove a bunch of timing there. Most of that is right as I punch it to WOT from a dig.
I also had quite a bit in the .88/4000 region, also at WOT & mostly after the 1-2 & 2-3 shifts. Those areas of KR tapered off as my RPM's went higher, so I'm still able to run 25-27 at 6000-6400 RPM's with no KR. I also smoothed up all the areas around the KR accordingly.
I figured right at 11:1 compression with my heads & cam, & unfortunately all we have around here is 91 octane (no ethanol), so no 93 to try out.
Stock fuel pump & SVO red top injectors tuned with the Greg Banish tables. I haven't hooked up a gauge to check fuel pressure, but my injector duty cycle never goes above 78% or so & I'm running 12.95 AFR at WOT.
I've never heard any pings or knocks at all coming from the engine, but I do occasionally hear something banging underneath the car at WOT. Exhaust or suspension or something, just not sure what & haven't been able to track it down. But, I also heard this when I was cam only & never had these KR issues then. That said, I just now got tires that can actually hook from a dig. I was just spinning my run-flats when I was cam only, so that might not be much of a comparison.
Anyway, I don't have a lot of experience here & was just looking for some more opinions.
