Results 1 to 9 of 9
Thread: Stock PE vs Tuned PE
    Question Stock PE vs Tuned PE
    I have had my 06 GTO WOT dyno tuned only, and have been looking at various tunes from the repository and now I have a few questions before I change the settings...
    On my original tune it has the following settings under PE enable:
    Delay RPM : 1000
    Enable RPM: 1200
    RPM Hyst.: 20
    but after downloading and analyzing several tunes, the following settings are in almost all of them:
    Delay RPM: 5000
    Enable RPM: 1200
    RPM Hyst.: 50
    why? and What effects do they make in drive-ability / throttle response?
    Do you think that it is my tune that has been altered? Thanks in advance
    Jul 2004
    1,579
    Has nothing to do with performance, but mostly related to fuel efficiency and durability (warranty reasons).
    Senior Tuner IDRIVEAG8GT's Avatar
    Aug 2010
    Roswell, N.M.
    1,956
    Set the delay and all that crap to zero. I watched a tutorial here on HPT that explained it's a bunch of bullcrap.
    Gray Ghost- The abomination. 2007 Chevrolet Silverado CCSB. 98mm turbo, nitrous, 428LSX, Rossler 80E with a brake. Finally finished. 23 psi, no numbers, Slow as hell.
    PBM G8- Aluminum 364, twin Precision 67/66 turbos, 6L90 trans swap, CTS-V/Vaporworx fuel system, slowly making progress.
    Dads 2011 CTS-V- Stock bottom end, stock heads, LS9 cam, pullies, ported blower, ported TB, D3 goodies, and lots of nitrous.
    618/618 motor
    906/862 spray
    Caterpillar 50 Forklift- Duramax swap
    so set the delay to the same as the enable?
    Advanced Tuner ajamesbond007's Avatar
    Dec 2010
    288
    G8GT - Where did you find that tutorial?
    Andrew
    2006 Duramax ECSB - Banks Monster Dual Exhaust, Tie Rod Sleeves, Kennedy Twin Deluxe Lift Pumps, Edge Insight CTS with Pryo, EGR Blocker Plate, PVC Reroute, Suncoast Stage 5 trans with 1056 triple disk converter, Cognito Steering Braces, PPE Race Valve, LML driver side exhaust manifold, AFE Boost Tube, Stock Drop-in BatMoWheel, ProFab Performance 3" Downpipe, Other mods along the way, TUNED by ME... Way too much fun
    Anymore info on this, and exactly what it does?
    Advanced Tuner madvette08's Avatar
    Jan 2009
    Tampa, FL
    427
    There is a timer for when it will go into Power Enrichment. Once your over 5000 rpm it will ignore the timer to go to Power Enrichment. On cars this timer is set to zero, so if your below 5000 rpm it will ignore PE Delay RPM. On Trucks this timer is set to 1.0 second before it will ignore the PE Delay RPM.
    2008 Corvette A6 - Comp Cams 231/239 617/624 109 ICL 113 LSA, Patariot Extreme Dual Springs .660", Milled .30" Stock LS3 Heads, Mahle -4cc pistons, FTI 3600 Converter, 1 7/8 kooks cat-less 3 inch X-Pipe, air raid intake, ported TB, SLP Loudmouth I. 512hp/464tq
    2011 Ford Taurus SHO - stock with just a Tune
    I went ahead and set it at 1300, that way, when I nail it from a slight roll, I am in PE in no time...
    I was led to understand that it sort of blended the open loop and closed loop up intil the enable RPM.
