Im having issues with this tune,as soon as the truck warms up it starts to run very rich and stumbles. right bank 02 sensor goes nuts here is the tune thanks. Ok how do I post my tune, it wont let me copy it any help would be great
a log and cfg. would be even better.
04 6.0 silvy china turbo
87 gn
03 stroker evo ww
00 ss camaro
what do you mean, o2 sensor 'goes' nuts? A well functioning o2 will rapidly toggle voltage. One that is flat lined is either rich or lean (which you dont want in CL)
Also, if you want to be in SD, you need to FAIL the MAF, doesnt appear to be.
Set P0101, 102, and 103 to fail on first error and uncheck the SES box. In the engine diag on the next tab over from the DTC's, set the MAF fail freq to 0Hz.
Have you attempted a VE tune?
No not yet on the ve tune, just got it running on 2 bar. Im going to log it and then post this week, has been crazy. Thanks for looking I will check what you have said. Iam going to switch too my 60lb dekas but wanted to change only one thing at a time just to be safe.
