Is this possible? My buddy has a 96 5.7L half ton and wants me to tune it. So I was curious if I could take a 97 5.7L ECM and put it in his truck and then tune it???
Let me know what you think
Andrew
2006 Duramax ECSB - Banks Monster Dual Exhaust, Tie Rod Sleeves, Kennedy Twin Deluxe Lift Pumps, Edge Insight CTS with Pryo, EGR Blocker Plate, PVC Reroute, Suncoast Stage 5 trans with 1056 triple disk converter, Cognito Steering Braces, PPE Race Valve, LML driver side exhaust manifold, AFE Boost Tube, Stock Drop-in BatMoWheel, ProFab Performance 3" Downpipe, Other mods along the way, TUNED by ME... Way too much fun
GM makes pcm's compatible alot of the time but its in no way 100% going to work.
Example
97 camaro v6 pcm's can be swapped into 96's
05 grand prix v6's into 06's, etc.
but its luck of the draw really, first the connectors would need to be the same, as do all of the pins if I'm not mistaken.
-Bill
