Results 1 to 20 of 40
Thread: hard start after new injectors
    Aug 2010
    Detroit, MI
    947
    Just installed some Siemens Deka 60s in the truck in my sig. Idles fine, runs great, but it takes several seconds to crank up and just barely manages to get going. After that, it acts 100% normal. I can't imagine the starter is liking this extra workout.
    I thought it might be the cranking enrichment in the FA Mult Stage 1 vs Time table, so I tried decreasing the ratio since the injectors are larger, but it didn't change anything. It was a bit of a shot in the dark anyway.
    Anybody had experience with this issue on a Gen4 engine before? Tune and log of startup is included.
    Tuner 4evervette's Avatar
    Jan 2008
    dyno room
    169
    didnt open ur tune... have u change the injector data ... IFR ,,ofset inj.mpw etc ?!
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,860
    As stated... Did you enter all the proper data for the injectors? There are more tables than just flow rate. Did you enter flow rate properly for that matter.?
    http://www.dsxtuning.com
    Just say no to bull s***.
    Senior Tuner IDRIVEAG8GT's Avatar
    Aug 2010
    Roswell, N.M.
    1,956
    +2.
    Gray Ghost- The abomination. 2007 Chevrolet Silverado CCSB. 98mm turbo, nitrous, 428LSX, Rossler 80E with a brake. Finally finished. 23 psi, no numbers, Slow as hell.
    PBM G8- Aluminum 364, twin Precision 67/66 turbos, 6L90 trans swap, CTS-V/Vaporworx fuel system, slowly making progress.
    Dads 2011 CTS-V- Stock bottom end, stock heads, LS9 cam, pullies, ported blower, ported TB, D3 goodies, and lots of nitrous.
    618/618 motor
    906/862 spray
    Caterpillar 50 Forklift- Duramax swap
    Aug 2010
    Detroit, MI
    947
    Yes, I made changes to the IFR table, short pulse adder, minimum injector pulsewidth, and injector offset. It runs fantastic at idle and any range from there to WOT.
    May 2007
    Denton, TX
    68
    Did you by chance happen to change out the fuel pump when you did the swap to the larger injectors? It sounds like your fuel pressure has bled off and there in none in the fuel lines. Cycle the key a few times and be sure there is fuel rail pressure when you start it and see if you have the same issue. I've seen guys put pumps in that don't hold the fuel pressure after shutoff have the same issue. A simple fix could be a momentary push button to run the pump a few seconds before starting if that is the problem.
    Aug 2010
    Detroit, MI
    947
    No, theres pressure in the lines all right. I watched it on my fuel pressure gauge and in the log. It never drops below 58 in the log.
    that ifr looks a lot like the factory flex fuel injector data
    Aug 2010
    Detroit, MI
    947
    Quote Originally Posted by omar alejandre View Post
    The IAT modifier table multiplies those values by 2.
    Mar 2008
    St. Louis, MO
    4,860
    Quote Originally Posted by smokeshow View Post
    If you're trying to beat the 63.5 lb/hr flow rate limit of injectors... then what you did doesn't work.
    Aug 2010
    Detroit, MI
    947
    Really? I got that recommendation from Justin at Blackbear tuning. He definitely knows his stuff and I doubt he'd steer me wrong.
    Mar 2008
    St. Louis, MO
    4,860
    Everybody always knows their stuff.
    Aug 2010
    Detroit, MI
    947
    Well I am still looking for suggestions from the people that do...
    Aug 2010
    Roswell, N.M.
    1,956
    I think Steck called it right, and it needs to be re-scaled. However, if it's a hard start, Startup Airflow tables and adjustment of start up timing would be the easy way out of your situation.
    618/618 motor
    906/862 spray
    Or just run injectors that you can properly calibrate for. A 60lb injector is good for what like 800-900hp or more at 58psi. You have is a stock 5.3 with 10psi looking at your sig. can't see that needing those injectors.
    2001 Z06 - 417 LS3 - LPE CNC LS3 heads - LPE GT-11 cam - ARH 1 7/8" - LPE C6 intake - RPM 3.73 diff - tuned with HP Tuners
    2008 Silverado 5.3 - Dynatech LT headers - Volant Cool Air intake - 280whp/303wtq - tuned with HP Tuners
    www.davenportmotorsports.com
    Aug 2010
    Detroit, MI
    947
    Quote Originally Posted by IDRIVEAG8GT View Post
    I've had several people say that, and I'm not discarding your suggestion, but why would I need to make airflow adjustments for just an injector swap? Is that just a simple fix to trick it into thinking its getting less air so it delivers less fuel? Forgive me if thats a dumb question; I haven't done any VE adjusting yet, as this is the first vehicle I have tuned. I did plenty of research before installing the injectors, and wasn't expecting the hard starts. It runs perfect aside from the starting issue.
    Quote Originally Posted by Sherminator View Post
    Tell that to the 120% IDC with my old 42lb injectors...
    Mar 2008
    St. Louis, MO
    4,860
    You need to scale the tune. That bullsh*t with setting the IAT vs. Fuel Flow multiplier to 2 doesn't work. Your injectors are passing the 63.5 lb/hr hard coded flow rate limit.
    Also, where'd you get the injector data?... Because it's not right for the SD60s, tall or short.
    Aug 2010
    Detroit, MI
    947
    Wouldn't it have driveability issues if that multiplier didn't work? Not saying you are wrong, but it runs perfect other than the starting issue. From idle to full boost, AFR is exactly what it was before with the old injectors.
    I got the injector data from a spreadsheet calculator, not sure who the author was.
    Aug 2010
    Roswell, N.M.
    1,956
    Yep. What I suggested is the quick and simple fix because it seems that those injectors in fact, have calibration data equivalent to what a set of 67 Lbers are for Bosch's that were in a CTS-V that I tuned here not too far back. Proportionally, the top part of the offset is way off compared to a fairly close bottom. Anyways, when you recalculate airflow it just holds the throttle body at a different position for more airflow to accommodate your fueling issue.
    Steck is going to call me a newb for suggesting this but FIC sells redrilled 60Lb injectors that start life as ZR1 injectors. But the IFR data hardly changes at all compared to a ZR1. That's what I have in the newest addition to the family of Silverado's sitting around my place with a 415 and they are fantastic.
    618/618 motor
    906/862 spray
    Mar 2008
    St. Louis, MO
    4,860
    Please stop telling people to buy crap. That's exactly what those are. You'd puke if you saw what the flow looks like coming out of redrilled injectors. Some of them just shoot a garden hose looking stream, which is bad.
    OP, that multiplier table is cracking your injector flow rate up to 63.5 no matter what, and closed loop is fixing things because fuel delivery is generically close enough.
