Can i get some help pls, downloaded a tune for this 2000 regal with the NA 3.8 and it says definition failed to load, can someone call me and walk me through e mailing a tune i have a custome waiting.
thanks in advance
Brian
509-280-8466
thanks in advance
Brian
509-280-8466
Brian@RPE Performance
(509)280-8466
not sure about your specific error but i will say when u download a tune it is usually for a car you ahve not unlocked and because of the vin difference you will not be able to flash it to another car even if that car is unlocked...
Could that be your problem?
also for another discussion flashing some tune you find online is dangerous
why not read entire of the existing tune and then actually TUNE it the right way? This way you know nothing is done wrong.
02 Regal GS - L67
Wizardair CAI, 3.4 pulley, SLP Headers
Watch out - 13s
Sometimes if I save it to a file instead of opening with HPT, it works.
You can then copy & paste to your car. pick & choose what you like,
The Regal has been laid to rest..... rust
Now have an 06 Lucerne with the 3.8 and wishing HPT would cover that car
Loved my 2001 Buick Regal GS.
With more than 334,000K, 3.4 & 3.6 pulley, Change stats and pulleys with the seasons, Upgraded grounds & power wire, Volt booster, Caspers timing commander(AKA happy knob), Spectra intake-fender wall, PLog, 3" DP & 2.5 exhaust, HPTunner 12" Impala duel piston front brakes, New trans,GMPP suspension... yada, yada...
