Results 1 to 6 of 6
Thread: etc not 100% and 33% with key on not running
    Oct 2008
    6
    not new to tuning, however, i have two vehicles that i have noticed the etc is at 80% at wot and 20-33% with key on and not running. any help
    Senior Tuner S2H's Avatar
    Apr 2005
    4,387
    thats very normal
    there are 2 different PID's for throttle position... one of them will show 100% at WOT, the other will not.
    try the other Throttle position PID.
    -Scott -
    Oct 2008
    6
    thanks. i will check that out
    Jul 2004
    1,579
    Throttle Position % (SAE) is the actual opening of the throttle blade, that is normal between ~15% up to 88% (WOT). That is what the ECM will open the throttle body to to keep the engine running at idle or what you request for operation. If you want to log what you are commanding like a typical TPS value (0% to 100%), log ETC Pedal Position (%).
    Nov 2011
    38
    Quote Originally Posted by 12secSS View Post
    SO in the option to disable the ACC (& and other options) at 98% TP which reading is it going to use?
    I thought the Throttle position % (SAE) was the duty cycle of the sensor. I thought (although could be wrong) that the pedal sensor was a duty cycle sensor rather than a Pot type sensor so that if you got a short in the wiring the engine will recognise a fault rather than think you're commanding WOT when you're not. I work on diesel trucks for a living and thats how they work on trucks.
    2010 GXP Maloo ute, LS3, 6L80E.
    MM heads, 240/252@50 solid cam, 12.75:1 compression, 4500 Dominator converter, 3.46 rears.
    Shooting for 10s eventually.
