I have been trying to get the Coolant Level Low and Check Coolant Level on the DIC to stop reporting. It also effects the Analog and digital gauge, as they are bouncing up and down from 25 degrees to 169. I have previously disabled P0128 and set to No MIL due to the ECM throwing XXX on the DIC and cutting the air conditioning off. I researched what I could find, and seen that the computer does not like the temp either not coming up fast enough, or not getting as hot as it would like. What else need to be turned off for the gauges to work correctly and the DIC to not report temp issues when there are none. I have a 440LS7 w/an electric WP and 160 thermostat. No temperature issues during the summer, but this thing drives me nuts during the winter. Thanks for any help that can be provided.
Also, I pasted a copy of my tune so you can see what all is what. If you see something out of whack, feel free to let me know. Still somewhat of a newb at this.
