I would appreciate all the comments and advice.
I have big bucking, surging and drivability problems. Car drives badly below 3K cruising or under wide open throttle. I've done some adjustments to the timing, fuel, MAF setting but to no use.
Many say the camshaft is causing this problem. Local tuners, in my part of the world, are saying nothing could be done about it.
Can the G6X3 be tuned to run properly? What should I do with HP setting?
A friend of mine have the same G6X3 setup on Pontiac GXP (except the fast intake) and he surge is only limited to RPM below 1200. While I hear some other LS3 guys are running ok with this camshaft.
I have attached some file and hope than I can get some feedback on the setting.
My set up includes:
Cam LG G6X3
FAST intake
Mild head porting
Underdrive pully
Headers 1.7/8
Magnaflow exhaust
Cold air kit
3.73 gears
