Results 1 to 4 of 4
Thread: pinched knock sensor wires casue kr* in logs?
    Jul 2009
    California
    224
    I thought I read last year somewhere in my searches that if you have a pinched/shorting wire for the knock sensors that it will show KR* always at 4K. It was said this was GM's way of alerting mechanic/tuner that this was happening because it always showed at 4k when happening.
    I ask because sometimes I show KR at 4k and only 4k and never anywhere else no matter what timing I have in those cells or higher octane. Burst knock tables dont show anything ever. I checked sensors by bumping timing up and got KR* through different cells so I know they are working....
    Im not really bothered about it tune/safety wise as it lasts a split second but im really trying to see if this is actually true.
    Tuning Addict WS6FirebirdTA00's Avatar
    Jan 2005
    Concord, NC
    8,093
    If it pinches or shorts it fails to max retard in PE and throws a code, from what I have seen.
    Sulski Performance Tuning
    Tuner seven ends's Avatar
    May 2007
    Houston, Tx
    155
    Disconnect the knock harness temporarily and check with ohm meter....should read roughly 99 ohms if its the same sensors as my LS6.
    Edit: Also the grounding is particularly sensitive and important for the sensors. I did my trans in/out a while back and got a painted bracket in between the block and the ground. Even though its the same bolt, it caused me low signal issues until I figured out the KS were good and got the ground directly on the block again. Grounds should be clean, not broken, and secure. cheers
    Last edited by seven ends; 02-28-2011 at 07:55 AM. Reason: Add note about grounding.
    2010 Avalanche 4WD; AES 390; Mast LS3 heads; VVT Cam; ported TVS2300; Overdrive 8 rib pulleys; 2.7 snout pulley; ID1000; LS3 TB; WB 450; Twin MM cans; built 6L80; CircleD Triple Disk, CSR flexplate; Trucool 40K; Aeroforce Dual; AFX
    Remember proper torque for these as well. 15ft/lbs only for both the LS1/6 style and the newer LS2/3/7/9. Their sensitivity is effected if they aren't torque properly.
    2001 Z06 - 417 LS3 - LPE CNC LS3 heads - LPE GT-11 cam - ARH 1 7/8" - LPE C6 intake - RPM 3.73 diff - tuned with HP Tuners
    2008 Silverado 5.3 - Dynatech LT headers - Volant Cool Air intake - 280whp/303wtq - tuned with HP Tuners
    www.davenportmotorsports.com
