Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
Thread: Anyone dealt with a 3.3 bar Duramax MAP?
  1. #21
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,859
    Yea, I have three bar sensors that'd work, have the low end resolution, and are plug and play.
    http://www.dsxtuning.com
    Just say no to bull s***.
  2. #22
    Advanced Tuner blownbluez06's Avatar
    Jan 2008
    Forney, TX
    982
    The 3.3 bar Duramax sensor is junk. played with it for a year. The accuracy and resolution is not good. I had a customer going into REP on a 1514 with the tune scaled down and 1514 table maxed. Was hitting 1514 and going into REP while cruising steady state. That sensor turned out to be the cause of it. Motorola makes a nice, accurate 3.0 bar chip that you can solder into your old housing and it works real nice.
    Hsquared racing engines RHS 427, Procharger F2, Moran Billet Atomizer injectors, Alky Control,Mast LS7 heads, Nitrous outlet kit,Tilton quad disc clutch, DSS shaft, RKT56 ZR1 trans, RPM Quaife diff. Built and tuned by yours truly.
  3. #23
    Oct 2009
    229
    Just tried another one .. same crap ... am I the only one with this issue ?
    I used to 333.33 / 33.33 calibration ..
    Both sensors throw the same p0107 code and im getting a high idle as well .. round 750 when im commanding 600.
  4. #24
    Dec 2008
    on the Dyno
    1,825
    The motorola 3bar surface mount sensor is basically the same chip I'm assuming based on the datasheets from both sensors. They both have the exact same transfer function. 1.11kpa to 315.58kpa.
    Located in Central Kentucky
    ShorTuning
  5. #25
    Wondering if anyone using these duramax sensora with any luck? I've had my efi source 3 bar come apart looking for factory 3 bar. Ctsv, zr1, duramax?
  6. #26
    13,564
    They don't work well or at all.
    Stick to a regular 3 bar sensor.
  7. #27
    Which ones work well
  8. #28
    Quote Originally Posted by prostreet1967 View Post
    I've been using the 3.3 bar sensor since 2012 without any issues. Granted I don't drive my car very much, but you can try this part number and see if it is still available from the dealer. GM #12623671 along with the calibration we spoke about earlier in this thread.
    " '01 SS "
