I was told to try reducing the Closed Loop Proportional Mode by 15% and to reduce the Minimum Injector Pulse-width by 10%, to get rid of O2 switching error codes P0134, and P0154. caused by Long tube headers high flow cats, the O2 sensor voltage drops to much because they get get while idling over 2 minutes voltage drops from 550mv to 480mv in about 2-3 minutes of idling.
where are the Closed Loop Proportional, and Minimum Injector Pulse-width tables located on the E40 PCM? And how to high specal paste - 15% ? I see hoe to times by 15% but not hot to reduce by 15%.
under engine/ fuel management / Cl & OL I see mode vs. air flow would this be the same as Closed Loop Proportional Mode??
under engine/ fuel control / general / makup pulse with min, is this the same as minimum injector pluse-width??
The guy who gave me this info has a 2000 camaro LS1 style computer, thats why maybe the terms are different than the E40, will trying this do any harm? I am sick of the O2 codes!!
THanks -Jamie
