will the zr1 2.5 bar map sensor fit the ls2 connector?
if so what is the part number?
-carl
-carl
12592525 is the ZR1 MAP part number. You need an adapter harness from Katech and have to drill the hole in the manifold out to 12mm I believe. The harness is $40.
http://www.dsxtuning.com
Just say no to bull s***.
hey carl is the zr1r map a 2.5 or 3.0 bar? offset indicates 3.0
[IMG][/IMG]
thanks guys, i think im just gonna keep my 2 bar and keep it under 15psi, (stock bottom end) =P
Carl, FYI: If you are using the Saturn/Cobalt baro sensor that most of us use that is a 2.5 bar sensor.
Bill Winters
Out of the LSx tuning game
mine is a 0698 p/n
Yea, you're right. Not sure what I was thinking.
Kind of a bummer because now I know I'm maxed out where I am (14#) as I use the same sensor...
Bill Winters
IS this sensor a direct fit for a 2000 c5 intake/ wiring harness ? whats the full part number ? what would the offset values be for o/s ..Decided to go this route SD tune, wide band o2 an no maf . Just changed the dam oil sending unit .... guess the intakes coming back off o well make it easy to drop in the seima 60 s then
GM pn 12580698..... found it
