hello...
i noticed after 6200 my dyn cyl air starts dropping from 1 untill it reaches .87 at 7000rpm...
how does dynamic air correlate with power output.. does it mean i'm losing way too much power taking it to this high rpm? should i shift sooner?
the only reason i'm pushing it this hard is because its an A4 with a 308 diffrential so after my 2nd to 3rd shift my rpm drops way too low to around 4300 so i thought maybe taking the 2nd gear higher would help
what do you guys think?
could the drop in my dyn air be caused by my stock small maf?
this logged run is during maf tuning so the ve is disabled by setting dynamic airflow high rpm disable to 200rpm
its a 2004gto
l98 engine 408 stroker
l92 heads
102 fast manifold and 92 TB
AEM bruteforce intake for the ls2 but i changed the filter because it was too large for my maf
