I cant load HPL files. You have to export them in CSV or TXT format first.
Free HP Tuners Beginners Tuning Guide
LS1 Tuning Guide
Michigan Snowmobiler
1969 Firebird: 11.67@114 [email protected] 1/8 1.70 60 ft. EPS cam 234/246 .602.606 114+3, 6.0 LQ4, L92 heads milled 10.5:1, Ported L76 intake, ported 90mm Holley TB, 100mm MAF, FIC Custom injectors, Hooker LT, PYPES dual exhaust with an X pipe, 4L65e with all of the good parts inside, FTI 4000 RPM Stall, 12 bolt with 3.73 gears. HP Tuner tuned by me
Looks like you are shifting gears. A run needs to be made in a single gear I think thats your issue. Its like you would on the dyno not a drag strip. Let me know if this helps.
1994 Mazda Miata turbo, aero, hoosiers Class=SSM
Take my drop box referral and we both get an extra 250 Mb free!
Did you trim your log to only include the data points for the gear you selected? You're going to get improbably high results by including the first and second gear data points if you've selected third gear.
You only have a very narrow band of data points in the log for either second and third gear - unlikely to get a graph that is terribly useful. That's the problem with auto's with high stall converters, tough to get a good log. Auto's work best if you lock the torque converter and only do a run in one gear.
2005 Grand Prix GXP - 5.3 LS4 - HP Tuned, MF catback, 1.8 rockers, K&N, Some day I'll finish putting the LS6 intake on
I have trimmed the data points to only the few seconds of the pull.
rename the file to a .csv.
2002 Z06
<?xml version="1.0" standalone="true"?>
-<CarDataset xmlns="http://tempuri.org/CarDataset.xsd"> -<CarParameters>
<CarMake>Chevy</CarMake>
<CarModel>Corvette Z06 (Manual)</CarModel>
<Weight>3110</Weight>
<TransGear3>1.43</TransGear3>
<TransGear4>1.00</TransGear4>
<FinalGearRatio>3.42</FinalGearRatio>
<DragCoefficient>0.373</DragCoefficient>
<FrontalArea>20.7</FrontalArea>
<TireDiameter>25.5</TireDiameter>
</CarParameters> </CarDataset>
I have trimmed mine down too, third gear only. Still get crazy numbers.
LS1 Tuning Guide
I know man. It's not even close. I don't understand it.
Ill try this myself in a bit ... Driving right now.
No luck either?
I got it to graph but i dont know what the numbers should be. They werent high I wouldnt think in the beta I just tested them in. Can you show me a screenshot of how high they were? Thanks guys. Hopefully I can get this issue resolved asap and get this released soon.
Here ya go.
LS1 Tuning Guide
Well, I gave it a shot with a couple of different tools I use. Here's the result using Brad's program:
Attachment 27655
Here's the result using an excel program that calculates power based on smoothed acceleration and air resistance:
Attachment 27656
Torque calculates out a bit differently, but peak HP is virtually the same - just over 420 WHP. Are you sure you were running nitrous on that run?
**edit - I assumed this was third gear. If fourth, then yeah, the HP number is 888**
I need to know how much the passengers weighed in the pull to be able to graph it. With 200lbs of passengers it showed 461hp.
Vehicle weight is 3118. Passenger and nitrous bottle is another 250.
Yes it was a 150 shot. Just a plug check for tuning.
Here is another 150 pull.
Time Engine RPM (SAE) rpm Vehicle Speed (SAE) mph Throttle Position (SAE) % LC1 WB afr
00:58.1 3438 53 100 14.63
00:58.3 3651 57 100 14.03
00:58.5 3802 59 100 14.54
00:58.7 3963 62 100 14.25
00:58.9 4126 64 100 12.48
00:59.1 4316 67 100 12.82
00:59.3 4482 70 100 13.54
00:59.5 4663 73 100 13.69
00:59.7 4818 75 100 13.51
01:00.0 5006 78 100 13.12
01:00.2 5181 81 100 12.67
01:00.4 5375 84 100 12.23
01:00.6 5481 86 100 12.28
01:00.8 5642 88 100 12.04
01:01.0 5782 90 100 11.91
01:01.2 5919 93 100 11.75
01:01.5 6079 95 100 11.63
01:01.7 6197 97 100 11.41
