Page 27 of 32 FirstFirst ... 17232425262728293031 ... LastLast
Results 521 to 540 of 633
Thread: Brad Barnhill's Virtual Dyno with HP Tuners
  1. #521
    Jun 2012
    Grand Rapids, MI
    75
    Hi Brad. First I want to say thank you for providing this software! I love it and use it every time I am tuning!
    My problem is this: I have been having a new issue lately, where I open the program, it loads normally, but appears to stay minimized. clicking the program in the taskbar does not bring up the GUI and holding the cursor over the program in the taskbar shows a blank image in the little preview window.
    The only way I have found to actually get the GUI to appear is to right click VD in the task manager and choose "maximize". After that the program works fine, and I can minimize and maximize like normal.
    I have uninstalled, and reinstalled from your website to make sure I had the latest version with no change. This is on a Windows 7 machine. All other programs are operating normally, only VD is having this issue.
    Anything I can do to help fix this?
    Jack
  2. #522
    Advanced Tuner bbarnhill's Avatar
    Feb 2011
    Kansas City, MO
    200
    Quote Originally Posted by RooTBeeR View Post
    yeah, didnt use to, but the last few weeks(i hadnt used it for a while before that) it has been doing it, it loads fast till the point in the pic and then stops for about 2-5mins everytime
    Thats not supposed to do that except when new car defs are available. Wonder if permissions have changed on that folder. check that your c:\users\<username>\appdata\roaming\Virtual Dyno\
    folder is accessible and open for reading and writing by your user. Have you reinstalled to see if that helps for some reason?
    Brad Barnhill
    VIRTUAL DYNO
    The ONLY way to graph your runs.
    Click here to donate
  3. #523
    Feb 2011
    Kansas City, MO
    200
    Quote Originally Posted by cptinjak View Post
    Jack
    Yes this is an issue that is addressed in the new version that Im about to release (1.1.9). It stems from having the program minimized and closing it while its minimized. You need to go to your data directory (c:\users\<username>\appdata\roaming\virtual dyno\) and edit the graphsettings.xml file and LEFT and TOP should be greater than 0.
    Brad Barnhill
    VIRTUAL DYNO
  4. #524
    Jun 2012
    Grand Rapids, MI
    75
    Quote Originally Posted by bbarnhill View Post
    They are both currently -32000. what should I replace them with? Edit: CAN I change them?
    Jack
    -2000 C5
  5. #525
    Tuner RooTBeeR's Avatar
    Feb 2009
    Chino, Ca
    106
    You nailed it! thank you sir.
    The permissions had changed for some reason.
    Caution:Slow Learner
  6. #526
    Feb 2011
    Kansas City, MO
    200
    awesome sauce!!! Let me know if you need more help. Post what you think about it.
    Brad Barnhill
    VIRTUAL DYNO
  7. #527
    I can't seem to enable the "save as custom" in the car editor.
    For all intents and purposes my frontal and drag coefficient should be the same as a Gen III Silverado. My tire height is 29.7 but my truck is a 5 speed with ratios as follows: 1st - 4.02, 2nd - 2.32, 3rd - 1.40, 4th - 1.00, 5th - 0.73. Weight of my vehicle with driver is 4610 (I am 210 lbs). How can I go about setting this up? This seems to be a great tool and I'm sure its going to prove extremely useful on the strip at the next test and tune
    Edit - PS this profile could be used as a generalized Gen III Truck 4.8/5spd profile.
  8. #528
    Feb 2009
    Chino, Ca
    106
    I believe that he hasnt finished that part of the software for full release yet
  9. #529
    Feb 2011
    Kansas City, MO
    200
    @RSTinOKC: yeah I haven't finished that part of the software yet but at least you can view car data for now. Ill get to that eventually if they stop working me 8am-1130pm
    Let me know if those specs on that Gen III 4.8 are stock. If so then I can most certainly add it.
    Brad Barnhill
    VIRTUAL DYNO
  10. #530
    Feb 2009
    Orlando, Fl
    64
    Brad, I built a file based on one of my cars not in your DB. For some odd reason, when I connected to the internet and opened your application, it removed my file therefore it was no longer available.
    Code:
    <?xml version="1.0" standalone="yes"?>
    <CarDataset xmlns="http://tempuri.org/CarDataset.xsd">
      <CarParameters>
        <CarMake>Pontiac</CarMake>
        <CarModel>G5</CarModel>
        <CarSubModel>GT</CarSubModel>
        <StartYear>2007</StartYear>
        <EndYear>2008</EndYear>
        <Weight>2820</Weight>
        <TransTypeManual>true</TransTypeManual>
        <TransGear1>3.58</TransGear1>
        <TransGear2>2.02</TransGear2>
        <TransGear3>1.35</TransGear3>
        <TransGear4>0.98</TransGear4>
        <TransGear5>0.69</TransGear5>
        <FinalGearRatio>3.84</FinalGearRatio>
        <DragCoefficient>0.324</DragCoefficient>
        <FrontalArea>22.02</FrontalArea>
        <TireDiameter>25.46</TireDiameter>
      </CarParameters>
    </CarDataset>
    Your code seems to fairly acurate based off of a previous dyno pull on my car. Your software puts me at 175hp 171tq, the previous dyno was at 181hp.
    2006 Pontiac GTO 6.0L LS2 E40 6 Speed Manual
    2007 Pontiac G5-GT 2.4L LE5 E67 5 Speed Manual
  11. #531
    Feb 2011
    Kansas City, MO
    200
    Yes this is known ... it wipes out the Cars folder when I release an update for the car definitions. Thats the monkey wrench in releasing the custom car editor. Im having to rework some of the ways it reads XML car definitions to include a separate folder for custom vehicles. For now just keep a copy of your custom car and copy it back when it disappears. Sorry about that.
    Brad Barnhill
    VIRTUAL DYNO
  12. #532
    Feb 2011
    Kansas City, MO
    200
    1.1.9 has been released ... Enjoy!!!
    Brad Barnhill
    VIRTUAL DYNO
  13. #533
    Feb 2009
    Chino, Ca
    106
    Not sure what's going on now.
    I change the folder to read/write and click ok, then if I go back to the properties it immediately has reset to read only. Any ideas?
  14. #534
    Feb 2011
    Kansas City, MO
    200
    does it still take forever to open for you?
    Brad Barnhill
    VIRTUAL DYNO
  15. #535
    Feb 2009
    Chino, Ca
    106
    yeah, after the update it does.
  16. #536
    Feb 2011
    Kansas City, MO
    200
    man thats just weird ... have you tried a complete uninstall?
    Brad Barnhill
    VIRTUAL DYNO
  17. #537
    Feb 2009
    Chino, Ca
    106
    yup.
    i also tried to add a new folder to the roaming folder and it automatically made it read only and did the same thing when i tried to change it
  18. #538
    Feb 2011
    Kansas City, MO
    200
    man that does not sound like a VD issue unfortunately ... sounds like you have some permission issues going on.
    Brad Barnhill
    VIRTUAL DYNO
  19. #539
    Feb 2009
    Chino, Ca
    106
    yeah ill have to look into it later
  20. #540
    Feb 2011
    Kansas City, MO
    200
    keep me posted
    Brad Barnhill
    VIRTUAL DYNO
