Page 10 of 32 FirstFirst ... 6789101112131420 ... LastLast
Results 181 to 200 of 633
Thread: Brad Barnhill's Virtual Dyno with HP Tuners
  1. #181
    Advanced Tuner bbarnhill's Avatar
    Feb 2011
    Kansas City, MO
    200
    Its got to be an issue with Windows 7 and permissions on installation. Hum. Im thinking of having it install to a different directory to fix the problem. 1.1.0 may just do that. I ran into this problem using InstallShield as the installer and thought it was that causing the problem so I switched to NSIS but I guess it wasnt it after all. Im gonna research this a little bit more.
    Brad Barnhill
    VIRTUAL DYNO
    The ONLY way to graph your runs.
    Click here to donate
  2. #182
    Jul 2010
    371
    Its installed fine on windows 7 ultimate (32 bit) for me.
    1994 Mazda Miata turbo, aero, hoosiers Class=SSM
    Take my drop box referral and we both get an extra 250 Mb free!
  3. #183
    Apr 2006
    573
    Quote Originally Posted by bbarnhill View Post
    so it in there and the car just isnt showing up? send me the xml file. Maybe there is a little something wrong with the xml file that Ill find. bradbarnhill at hotmail com
    wouldnt let me upload the xml file so heres the text file..lol.
  4. #184
    Feb 2011
    Kansas City, MO
    200
    Looks like the first two lines may be the culprit ...
    It should read:
    <?xml version="1.0" standalone="yes"?>
    <CarDataset xmlns="http://tempuri.org/CarDataset.xsd">
    and not
    "<?xml version=""1.0"" standalone=""yes""?>"
    "<CarDataset xmlns=""http://tempuri.org/CarDataset.xsd"">"
    Brad Barnhill
    VIRTUAL DYNO
  5. #185
    Apr 2006
    573
    nope. still nada.
    basically the message i keep getting is "access denied". i try to put in the camaro profile and now it gives me error messages when trying to close the program.
  6. #186
    Feb 2011
    Kansas City, MO
    200
    what error message. Those error messages help me figure out what went wrong.
    It really sounds like you dont have permissions to write to that folder (installation directory), because on closing the app it writes your profiles and graphsettings to a file in that directory. If you dont have permissions it will throw an informational error message to let you know.
    Brad Barnhill
    VIRTUAL DYNO
  7. #187
    Apr 2006
    573
    that is what its doing.
    the only chevy profile still there is the cavalier profile.
    i made a camaro folder and everything but the cavalier is still the only profile.
    ive tried every form of xml that excel would let me save the file as.
  8. #188
    Feb 2011
    Kansas City, MO
    200
    You dont edit it in excel ... its xml format is funky. Use Notepad.
    Can you save the files to the Cars directory? If you can save files there its not a permission issue. If you can not save there then it is a permission issue. If its not a permission issue it has to be the file format you are using (saving it in excel can cause problems).
    If you want you can send me an email with your cars specs and Ill send you a copy of the file to just copy into the Cars directory.
    You can literally just throw all the xml files in the same directory under Cars. I just seperated them on installation due to being easier to manage on my side. When the program loads it just reads the entire directory structure and tries to load every xml file it finds.
    Brad Barnhill
    VIRTUAL DYNO
  9. #189
    Apr 2006
    573
    "Access denied"
  10. #190
    Feb 2004
    Charon
    46
    Try using an admin level account and see if it works.
    2003 GMC 1500 rcsb 4WD. LQ4, radix @ 7 psi, FLT Level 5 trans., 3.73 axle, 265 - 75 X 17 tires. Needs more bling.
  11. #191
    Apr 2006
    573
    Quote Originally Posted by GMC_DUDE View Post
    its not the computer. the program just isnt letting me do anything to it
  12. #192
    Feb 2011
    Kansas City, MO
    200
    Ill bet you three cookies that you dont have write priv. to that directory.
    Brad Barnhill
    VIRTUAL DYNO
  13. #193
    Feb 2004
    Charon
    46
    Agreed. Which is why I recommended trying an admin account. If that works, then he can adjust the directory and file privileges from there so that his user account will have r/w/x access.
  14. #194
    Jun 2008
    Charleston, SC
    969
    anyone getting this to display a c6 dyno yet?
  15. #195
    Feb 2011
    Kansas City, MO
    200
    It should support c6s if thats what you are asking.
    Brad Barnhill
    VIRTUAL DYNO
  16. #196
    Jul 2008
    Louisville, KY
    417
    When is the next release?
  17. #197
    Feb 2011
    Kansas City, MO
    200
    Soon as its ready. Its a pretty darn big release if I might say so myself. Lots of fixes. Ive got to get some more time in the next couple of days to tie up some of the code. Dont panic its coming.
    Brad Barnhill
    VIRTUAL DYNO
  18. #198
    Apr 2006
    573
    i got it, i hd to change the permissions for the admin.
  19. #199
    Apr 2006
    573
    got it to work for the most part. just gives me an error message if i delete unneeded data from teh csv.
  20. #200
    Feb 2011
    Kansas City, MO
    200
    it shouldnt unless you leave something partially in there or something ... send me a copy of your editted CSV and Ill tell you what is wrong with it.
    Brad Barnhill
    VIRTUAL DYNO
