Results 1 to 9 of 9
Thread: 1x Signal, 1 Bolt - Camshaft GEAR
    Sep 2006
    Lake of Como - Italy
    219
    hi guys,
    who knows the correct GM p/n of this item?
    here there are all the specs off all the gears, but less the one I need:
    http://www.ls2.com/forums/showthread.php?p=9948162
    thank you!!!
    Advanced Tuner c.u's Avatar
    Jun 2010
    Eville, IN
    282
    well the p/n 12591689 come`s back as timeing set for the express,savana, 4.8l,5.3l.6.0l .v8`s.
    Sep 2006
    219
    this p/n is for the 4x signal...
    I need the 1x signal.
    thank you.
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,859
    I don't think there is a 1x single bolt cam gear. You can use a 4x cam gear with a LPE converter box though.
    http://www.dsxtuning.com
    Just say no to bull s***.
    Sep 2006
    219
    wow, should be easiest than replace again the gear.
    do you have the p/n?
    thank you!
    Mar 2008
    St. Louis, MO
    4,859
    I'm not sure what the part number is for the single bolt 4x gear, but it is from an LS3. The Lingenfelter converter box is $254.95.
    http://www.lingenfelter.com/mm5/merc...gory_Code=C163
    Sep 2006
    219
    ok, the gear I need is not yet produced.
    I will change another time the camshaft ...
    bye
    Advanced Tuner jakebdb56's Avatar
    Oct 2006
    Houston, TX
    646
    What are you wanting a 1x signal for? There's no stock VVT OS that supports a signal from that 1x (same signal as what comes off the back of a GenIII camshaft ) cam gear. If you need that readout, just modify the valley cover to where you can put a gen3 cam sensor on the block behind the intake and catch the 1x off the camshaft, that is if the single bolt core you have has the two half rings on the back of the cam.
    '20 AT4
    '01 Suburban 2500 Dad Wagon
    Oct 2006
    Houston, TX
    646
    Which that cam core doesn't have that pickup ground into it. suuuucks
    '20 AT4
