I'm still a newbie on tuning, went to the track tonight and made three runs: 11.33@121, 11.17@123, and 11.36@121. On every single pass the car was hitting the rev limiter mostly on every gear (1->2->3->4). Tried to change the fuel cut off, max gear vs. rpm table, WOT RPM SHIFT and WOT MPH tables with no luck. Couldn't do log anything because one, im one of the "lucky" ones with new spi chips that can't do standalone data logging and second, the track people wouldn't let me run with the laptop in the car. Attached is my tune before i made the changes, any input that will help me fix this issue will be greatly appreciated. Like i said, I'm still a newb on this so please bear with me on this. Thanks!
Symptom: On the shifting event the car felt like it was holding the gear, then hitting the rev limiter and then shifting.
About my car:
Procharger D1SC (10psi of boost with water/meth), Circle D single 2800 stall, FAST LSXR 102mm intake (newest mod, haven't touch tune after installed this), Kooks LT's 1 7/8". Stock cam, stock internals.
