Quick rundown on the car:
QM600 cam (out of my car)
Ported/milled heads
FAST 102 manifold
headers
I had damn near this same setup on my car and it was fine. What happens is... when you shut the engine off, it'll rev down, but then it sounds like it hits again and comes back up, then shuts off. I could have sworn I saved a log, but apparently I didn't.
If you look at engine speed when you shut it off, it'll drop down from idle almost to zero, and then zombie back up to anywhere from 300 to 700, and then shut off. What I noticed was when you shut it off, ETC TPS % drops to 3%, and then opens to 20%. When it opens to 20%, that's what the engine revs back up. I have to assume there's just fuel puddled up (ZR1 injectors, so they may be hosing down the port wall more than ideal) and it's allowing it to diesel somewhat on shutdown. The static compression is somewhere around 12.5:1.
Am I just completely missing something? Is there anything to keep the throttle from coming back to 20% on shutdown?... It just doesn't make any sense that this is the only car that does this (have done plenty other Zs with equally big cams that have no issue). I'm even more puzzled because my car didn't do it. I know C5s have a park position... is there anything available for the E38 PCMs? Max Fail maybe?
