Results 1 to 20 of 20
Thread: Wideband Through EGR
    Nov 2010
    40
    Hey guys. I cannot figure out how to properly calibrate my wideband to work through my EGR. I have tried every formula I can think of. I have a digital AEM wideband gauge, which has a range from 10 to 18 AFR. With the car off, but the ignition in the run position, it is outputting about 4.29-4.31 volts through the EGR input. Can anyone help me out?
    Feb 2006
    Canada
    1,958
    Can you post a scan and your config file? You may have it right, a WB will give you the reading of the exhaust, even if the car is not runing. Left over gasses will remain in the exhaust for some time and show up in a scan of the car in the ON position. It will not show a "free air" reading while sitting in the bung.
    Nov 2005
    Houston, TX
    3,968
    That sounds about right. With the engine off it will be off the scale lean so at the upper end of the 5V.
    Bill Winters
    Out of the LSx tuning game
    Nov 2010
    40
    Shouldn't it read 5 volts though? My gauge is displaying "---" when it's at 4.29 volts. I would think it would still show a number. What formula should I use? It shows 10-18 AFR on the gauge, but the manual says it has a range of 10 to 18.5.
    Jul 2008
    Louisville, KY
    417
    Did you set the voltage offset in the scanner?
    Nov 2005
    Houston, TX
    3,968
    Which AEM is it?
    Bill Winters
    Nov 2010
    40
    30-4100 I believe.
    Nov 2010
    40
    I can't get the right slope for the formula because no matter which one I use, it is accurate at some AFR's and way off at other ones.
    Feb 2006
    Canada
    1,958
    Are you using [PID.2811]/.5+8.5?
    Did you connect to the solid brown wire, not the one with the stripe?
    Did you unplug the EGR harness at the EGR so the signal is only coming from the WB sensor?
    Nov 2010
    40
    I tried the [pid.2811]/.5+10 formula. Not even close. My EGR is deleted.
    Feb 2006
    Canada
    1,958
    Calibration screw is in the right setting I take it on the back of the digital gage?
    Nov 2010
    40
    Quote Originally Posted by MMGT1 View Post
    I'll double check tomorrow, but I'm pretty sure.
    Feb 2006
    Canada
    1,958
    Did you try 8.5 in place of that 10?
    Maybe try this one I came accross:
    100*(([PID.2811]/.480287467)+8.5-[SENS.121])/[SENS.121]
    Nov 2005
    Houston, TX
    3,968
    [pid.2811]/.5+10 is technically correct but if you're seeing low 4V in open air instead of 5V I would reduce the offset. So since it's ~4.3V instead of 5V I would change the +10 to +9.3. What are you seeing with this formula?
    Bill Winters
    Feb 2006
    Canada
    1,958
    5 liter is the guy that helped me set mine up a couple of years ago. I'd trust his input. So, that said, I am curious as to how you got the +10 for his WB when it actually has an 8.5 range for fuel when I looked his choice of WB up?
    Nov 2010
    40
    It's got a minimum of 10 AFR. That's why it's +10. I'll try the volts/.5+9.3.
    Potential Tuner badbird01's Avatar
    Feb 2008
    Alamogordo, NM
    3
    I found this thread while trying to do the same thing, it helped out a lot with explaining how to enter all the correct information(even though its for corvettes). Just read through all of it and you should be good to go.
    http://forums.corvetteforum.com/c5-s...hp-tuners.html
    2001 Red V6 Firebird
    Mods: Pacesetter headers, Magna flow cat back with 3in tips, high flow cat, whisper lid intake(raised), MSD coils, 8mm wires, CenterForce clutch, and of course my own personal tune.
    Future mods: upgrade valvetrain and then supercharge the hell out of it!
    Nov 2010
    40
    I'm still struggling with this issue. I can't find the correct formula to use. Ughhhhh.
    Jun 2011
    19
    I know Im late on here but Bedeards did you ever get this solved? Im going to attempt it this weekend
    Feb 2008
    Alamogordo, NM
    3
    Read post #1 and #5 very carefully from my link above and you should be good.
